Old 02-25-2019, 08:28 PM
RLause's Avatar
RLause RLause is offline
I would get one of these, drill a 5/8" hole vertically and bolt it to your hitch plate. If you keep it tight against the front of the hitch when marking the hole, when you tighten it down it will not move. Use a grade 8 bolt. This also gives you two different heights.
Richard
