Old 02-27-2019, 03:13 PM
35boulder's Avatar
35boulder 35boulder is offline
Default Removal of the brake pivot pin
I'm about to start splitting my CC 100 and was wondering if there were any tips on removing the brake lever pivot pin? Thanks
Old 02-27-2019, 03:16 PM
Very carefully!!
You DO NOT want to bust the 2 cast iron ears or you will really be screwed.
Old 02-27-2019, 04:08 PM
35boulder's Avatar
Okay, so I appreciate that heads up. Do you use a punch to drive the pin out?
A reminder, this is my first time to work on a CC. I'm just wanting to ask before I screw something up. Thanks
Old 02-27-2019, 04:12 PM
ironman's Avatar
ironman ironman is offline
Make sure you remove the adjusting bolt (that thing with the square head) COMPLETELY because it goes through a groove in the pin. That's what holds the pin in.
Old 02-27-2019, 04:15 PM
ironman's Avatar
PB Blaster it up real good and tap lightly with a punch. Work it both ways a little at a time.
Old 02-27-2019, 04:20 PM
35boulder's Avatar
So am I correct I should split the tractor then take out the pivot pin and brake lever? I this correct? I'm doing all this to do the brakes on this 100. Thanks
Old 02-27-2019, 04:36 PM
ironman's Avatar
you wouldn't necessarily have to split the tractor to get the pivot pin out, but what do you mean by "do the brakes". If they are not working, most likely the cause is that the piston is rusted up in it's cylinder. That will not be a fun thing to get loosened up, and will most certainly be easier to work on out of the frame.
Old 02-27-2019, 04:41 PM
35boulder's Avatar
Thats why I'm splitting. I need to replace the pucks and oring on the piston.
