Old 03-23-2019, 04:55 PM
Sooner's Avatar
Sooner Sooner is offline
Default 1641 With Vanguard Fuel Solenoid
I’ve removed the top of the carb for cleaning. Very dirty, old fuel,etc. I noticed the fuel solenoid won’t move when the key is turned to the on position. Looking for ideas. Thanx
Sooner Born and Sooner Bred, living in the Show Me State
Old 03-23-2019, 05:06 PM
RLause's Avatar
RLause RLause is offline
Are you getting 12 volts to the solenoid?
Richard
Old 03-23-2019, 05:26 PM
Que Sam stopping by to tell you to cut off the stem in 3,2,1............
Old 03-23-2019, 05:33 PM
Sooner's Avatar
I will check after the rain shower
Old 03-23-2019, 06:00 PM
What he said.
Old 03-23-2019, 06:08 PM
Sooner's Avatar
What he said.
So.... this isn’t needed? What was it’s intended purpose? Thanx
Old 03-23-2019, 06:17 PM
Anti backfire solenoid. Immediately shuts fuel delivery off so it doesn’t ignite from combustion temps after ignition is killed after shut down
Old 03-23-2019, 06:42 PM
Sooner's Avatar
Thanks for the reply. I’m getting 12 volts to the solenoid. Are these serviceable?
Old 03-23-2019, 07:55 PM
dale c. dale c. is offline
use a small pair of needle nose pliers and work it back and forth it might just be stuck ?
Old 03-24-2019, 11:00 AM
Just a FYI Briggs offers a plug to replace the solenoid.
