Old 03-23-2019, 08:20 PM
Default Rage 2 saw
I picked this up about a year ago and I have been using it to make my columns in the new shop. I had an abrasive chop saw but it got carried up to the road with a "Free" sign after using this.
Here it is cutting my 4"x4"x1/4" columns. Not too shabby for under $200 at Home Cheapo.
https://youtu.be/PR13sWm1Z4g
Old 03-24-2019, 07:17 AM
Sweet!
Old 03-24-2019, 07:55 PM
Nice, be interesting to see how long the blades last
Old 03-24-2019, 09:37 PM
Jeff, they say that 1 blade will last as long as 20 abrasive blades will. Time will tell. I think this is the cheap version sold at the box stores so I don’t expect much for the price.
Old 03-25-2019, 01:59 AM
cubby102's Avatar
cubby102 cubby102 is offline
Those things are amazing! I'll never go back to an abrasive one. Far less sparks. Better cut. And doesnt seem to I produce as much heat.
Old 03-25-2019, 06:12 AM
I cut a 1/4" slice of the material in another vid and picked it up with my bare hands right after I cut it. Basically there is not much heat put into the material. It cuts pretty square too but I did need to grind the bottom of each cut to get it close to perfect.
Old 03-25-2019, 09:11 PM
Does it cut 45* too?
Old 03-25-2019, 10:51 PM
Yes it does.
https://www.homedepot.com/p/Evolutio...AGE2/203633549
Old 07-26-2019, 08:57 PM
How's the saw holding up?
No fun throwing sparks in the summertime heat
Jeff
Old 07-27-2019, 08:10 AM
No complaints about it so far. When I built my floor drain covers it worked awesome. I set up a jig and cut all the pieces and then welded them up.
When I cut my 4"x4" steel columns I did have to grind the bottom of the cut to get it a perfect 90*. It looks like the blade flexed as you reach the bottom of the cut but that was some pretty big and heavy stuff.
