Old 03-27-2019, 07:42 PM
Sooner's Avatar
Sooner Sooner is offline
Default 1641 Brake/Neutral Problem
As this is an ongoing project, I had a new issue today. The brakes were backed off[no parking brake], so I adjusted the clevis pin 2 turns. Reattached, test drove, brakes function, but won't kick into neutral. A couple of times the pedal only went partially down, as if it was jammed. Any help would be appreciated
Sooner Born and Sooner Bred, living in the Show Me State
Old 03-28-2019, 07:11 AM
Are the linkages binding??? Do they need lubrication??? Are the linkages adjusted too tight???
Old 03-28-2019, 09:17 AM
Sooner's Avatar
I will look at those issues.... after coffee
Old 03-28-2019, 09:51 PM
Sooner's Avatar
The speed control linkage cam plates were dry. I’m learning and listening. Thanks again
