Old 04-04-2019, 10:23 PM
BigMike1475 BigMike1475 is offline
Default Help please???
Working on my newly acquired 149 and found I need to replace the spindle drive belt and pto drive belt that goes to the deck. I have found my model # of my tractor ( 2050047U) and the tag on the deck is 381 U1116. What deck do I have and where do I find my belt sizes??? I have looked at the belt and blade chart listed in the forum but must not be reading it right cause I cannot figure it out. Any help is appreciated....
File Type: jpg C952321C-2CBF-429B-A277-93E2BE861AF0.jpg (31.9 KB, 149 views)
File Type: jpg 3DC3A5DD-D269-4251-8D56-ACD1B9BBE532.jpg (29.2 KB, 150 views)
Old 04-04-2019, 11:42 PM
sawdustdad's Avatar
Maybe this will help. You have a 38 inch deck. I can't seem to find the deck S/N breakdown, so if you deck has cast iron ends, then use the first listing instead. Since it's on a 149, it should be one the third version (71-74) but who knows what someone else put on the tractor, so it could be anything.
Somebody else will chime in shortly with the exact deck S/Ns. But since the two later models use the same belts, unless your deck has cast iron ends (instead of sheet metal) then the listings circled should work. Your tractor serial number is in 472205.
Old 04-05-2019, 03:25 AM
Thank you for the help. Still learning to decipher the serial numbers...but this helps me a lot.
Old 04-05-2019, 07:45 AM
381 U1116
The Deck Model numbering system is a bit confusing. The best as I understand it, the first two digits (38) indicate it cutting width.
Haven't figured out what the third digit indicates.
The 'U" means it was made in the USA.
All decks seem to start with "1111" being the first production. 1112 would be the second generation, and 1113 would be the third, and etc.
Yours seems to be the 6th generation of the 38" deck.
In the CPE-2 Parts Manual, sometimes you see a distinction in part numbers based on the "1111" number.
The belts you are looking for are:
* IH-490489-R2 PTO Belt (3/8" x 80")
* 954-3002 Spindle Belt (1/2" x 72")
That is the best I can give you.
Old 04-05-2019, 08:14 AM
ironman's Avatar
ironman ironman is offline
If it were me, and I have the old belts which did fit and worked, I would measure them, like this....
https://www.youtube.com/watch?v=DYEk5UFyN94
to get their size.....
and I would got to this chart....
http://cubfaq.com/belts.html
to find the belt sizes(s) in red, that you measured, and you will have your part number. Voila!
Old 04-05-2019, 08:45 AM
sawdustdad's Avatar
That belt chart/table is handy! Forgot about that one.
Old 04-05-2019, 09:45 AM
sorner's Avatar
sorner sorner is offline
Or just do what I've done a few times, go to TSC and measure the old belt, buy a new blue belt, go home and find that it's an inch too big or too small, and go all the way back to exchange it...
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
Old 04-05-2019, 10:26 AM
Or if it's like a lot of the crap these stores sell, you'll be going back again in 6 months to get another because the 1st one came all apart.
Case in point their cheap aZZ grinder wheels and emery cloth grit strips.
Old 04-05-2019, 06:11 PM
Thanks again for all the help. Trying to get it right the first time because I have done the multiple trips to store to get right size belt before...
Old 04-05-2019, 08:12 PM
Yes, I miss that one being on our forum.
