Old 04-22-2019, 05:56 PM
Newtocub Newtocub is offline
Default Running hot??
I finally got my mower deck on and working good and it acts like the motor wants to run hot. Stumbles and bogs down give it a little choke and it'll run for a while longer. Anything I should check on it? It's a 100 with a 42" deck.
Old 04-22-2019, 06:12 PM
yeah. 1st thing, pull any tinwork you can and look down inside the front shroud and see how packed the cooling fins are. if they are packed with grass, oil, grease or a mouse hotel the engine WILL run hot.
these are air cooled and run hot anyways. WHat symptoms do you have that make you think that it's running "too" hot?
Old 04-22-2019, 08:12 PM
Started smoking a little and the gas was boiling in the tank.
Old 04-22-2019, 08:19 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Make sure you have the airflow and make sure you aren't running lean. Check your timing.
Plow blade
#2 Cart
QA36 snowthower
Old 04-23-2019, 08:57 AM
You might check that you have sufficient fuel flow to the carb.
Bogging down and saying pulling the choke helps, indicates a fuel problem.
Old 04-23-2019, 10:44 AM
twoton twoton is offline
What's the recent service history?
Old 04-23-2019, 09:23 PM
Thanks for the help guys. I took the little shroud off of the cylinder head and it was packed full of dust and grass working perfect again
