Old 05-25-2019, 10:11 AM
Livefreeordietryn2b Livefreeordietryn2b is offline
Default Cub Cadet 104 rebuild
I hope I put this in the right thread. I started to go through and disassemble my new found Cub 104. So far the known issues, it needs a brake clutch pedal, the pedal snapped off and bar is seized into the bushings, it needs a new carburetor, and the clutch disc for the drive shaft. It will need new tires and tubes. The console where the battery rests will need fixed or replaced. I have been looking around online for parts and tires apparently 6.00 12 tires are not the same as 6-12 tires. I am looking for the V pattern tires because I live on a hill and the clay here is as slick as bull snot. This is just a few of the things I need to fix. I am also possibly looking for the creeper gear box.
Old 05-25-2019, 10:16 AM
First, welcome to OCC....
YUP, they are the same.
Old 05-25-2019, 10:35 AM
Ok Thank you really want the BKT tires. They are 6.00 12s.
Old 05-26-2019, 07:33 PM
Well guys got the tractor all stripped down looks like Im going to need a steering box as well not sure if I'm gonna put mower deck back on or try to convert it to a pull behind mower deck and mount an engine still on the fence I will need to repair or replace where the battery tray is and where the clutch arm mounts as well and gonna need that brake clutch pedal had to cut it off to get it out plus pedal is broke off. I will need a few clutch parts as well. If I could find a parts 104 I'd be golden I posted a want ad here and other places hope I can locate something to get this thing running definitely need it bad.
Old 05-26-2019, 09:05 PM
sawdustdad's Avatar
There is a Cub Cadet Buy Sell Trade group on facebook if you do that. See lots of stuff for sale there.
Old 05-27-2019, 09:10 AM
ironman's Avatar
ironman ironman is offline
Here are links to three of them. Takes 30 seconds of DIY time.
https://www.ebay.com/itm/Cub-Cadet-1...ty!15136!US!-1
https://www.ebay.com/itm/Cub-Cadet-G...sAAOSwwgBcLmio
Old 05-27-2019, 10:16 PM
Thanks for the links I didn't find those ones since I've been searching. I've been searching and researching for a few days for hrs looking things up. I'll have to get some more pics of where I'm at with fixing it. I'll have to see if if that front PTO clutch assembly is worth fixing and the pulleys I know the mower deck needs rebuilt or replaced.Its missing the PTO lever and arm and the steering shaft is shot too. I just need to see what's the most cost effective approach.
Old 05-28-2019, 11:19 AM
I have found that 6.00 x 12 tires are sometimes the deeptread rice type tires that come on the front of import tractors. I have some on my OCC.
Walmart has some of the cheapest 6-12's. https://www.walmart.com/ip/Carlisle-...saAhrAEALw_wcB
Here is a pic of my OCC with 6.00-12's
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 05-28-2019, 07:54 PM
Thanks again nice looking Cub. If I can get the parts I'm needing either from a donor or a good price gonna repair the mower deck as well. Here's some pics.
Old 05-28-2019, 07:56 PM
More pics.
