Old 05-31-2019, 03:55 PM
Default AMO trailers
Hey guys
Anyone have an AMO trailer, thoughts/opinions? Looking at one of these...
https://www.usa-trailer.com/5-x-10-a-m-o-t8Pf.html
I was kicking around a TSC one for a while https://www.tractorsupply.com/tsc/pr...r?cm_vc=-10005 but I think for a relatiely comparable price range the benefits for the AMO outweigh the TSC one....plus it's a dealer vs a big box store brand. Just wondering if anyone has one, what do you like about it, dislikes, etc.
Payload will be 1-2 Cub Cadets (attachments) typically at 800-900 lbs each, occasional long distance (60 mile) firewood hauling, etc. Tow vehicle isn't an issue with GVWR.
Thanks
Old 05-31-2019, 04:21 PM
I do not care about the payload weight,, but,,,
once you pull a tandem axle trailer,,
you can never own a single axle trailer for anything but yard work behind a GT,,,
The second axle will cost almost nothing extra,, My tandem is only 10 feet long,,
JMHO,,,
Old 05-31-2019, 04:47 PM
cheesedawg82's Avatar
cheesedawg82 cheesedawg82 is offline
"I've never ever ever heard someone say they wished they bought a smaller trailer, and the difference between a 5x10 single and a 6x12 tandem is not all that much." -
My stepdad. It was good advice, wish I listened. I'd much rather borrow his than use mine most of the time.
I went with the used $200 4x8 off craigslist, myself, and it's certainly much better than not having a trailer at all. Bonus points that it's a good match for towing behind the Cubs and my Honda Civic, if it had a hitch.
Grumpy old 149/1A tiller, Trusty Rusty 106, & a Massey Ferguson 10 to work the garden, Tiny Snapper to mow the lawn. Slowly accumulating attachments and quickly driving the neighbors crazy on a half acre homestead.
Old 07-03-2019, 09:04 AM
Can two NF cub cadets fit on a 5x10? Or no? Should I think 6x12?
Old 07-03-2019, 09:25 AM
CubDieselFan's Avatar
Trailers are like shops, bigger is always better.
Old 07-03-2019, 07:18 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Putting two Cub Cadets with attachments onto one of these single axles trailer is cutting close to
trailer's GVW weight..... Perhaps a tandem axle, as mentioned before, would be a better idea! It's pretty easy to go over that limit when you hauling firewood. Usually the tandem axle have brakes, which is nice to have!
Plow blade
#2 Cart
QA36 snowthower
Old 07-03-2019, 10:43 PM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
I have a 6x12 that I can fit 2 Cubs nose to tail with little room to spare. 5x10 would be tight if it's even possible to haul 2 at a time. Also 5' wide limits the deck size you can haul.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 07-04-2019, 10:02 AM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Ten years ago I went trailer shopping. I needed to haul a four wheeler. It was my pre-Cub days. My tow vehicle was a 2000 Chevy Blazer with a 4.3 engine. The wife and I went looking at trailers for a couple of weekends. We hit the area trailer dealers, TSC and Rural Kings. The size I was looking at was a 6'x10'. I was hoping to spend $1,000 or less. The one trailer that stuck out to me quality wise was Sure-trac. But it was in the $1,400 price range a little more then I wanted to spend. We called my BIL who just bought a trailer. He told us of a town that had 3 trailer manufacturers and trailers in the $800 range. We took a 2 hour drive and went looking. Glad I had the wife along. She pointed out the things I didn't like. Used automotive tires, non treated decking, angle iron construction and wiring hanging from the frame. Yes all that for only $800 dollars. We went back and bought the Sure-trac. Tubular construction, treated lumber, powder coated frame, new trailer tires,LED lights, wiring run in metal tubes for protection and a ramp that can be removed or lays flat on the inside. Now at times I wish we had the 12' trailer. But it jumped to a 7'x12' which I thought was a little to big for the Blazer to tow. My point to all of this is shop around and weigh out what you want.
2-1811's
1872
2072
Old 07-05-2019, 01:26 PM
toyman's Avatar
toyman toyman is offline
I went thru a similar journey about a month ago and landed on a 6x12 Suretrack after looking at all the competitors in my area. Found the same shortcomings of the others, plus the Suretrack was heavier duty without adding a lot of weight.
Original Member #54
Old 07-05-2019, 09:50 PM
We went trailer shopping today. The 5X10 looked too small, and I didn't like that it limited the options for only hauling one PLUS I wouldn't have much margin of error on either side of my 48" mower deck. I opted to go with a 6X12 (for $200 more) that will allow for 2 cubs. 3500 LB axle and GVWR of 2990. I had heard concerns of some mowers bottoming out on the 4' gate but when I tested it out today it made the clearance just fine.
So far I'm pleased. Thanks for all the replies.
