Old 05-23-2019, 08:23 PM
Very inventive method of shake rattle and roll with screener. Maybe a few more times with it? Where did you source the other tank? Aftermarket?
I haven’t tried that red kote stuff but have heard decent reviews. Probably based on the interior of the tank being rust free though?
Old 05-23-2019, 08:26 PM
I do not see any rocks, is the new tank a direct replacement or do you have to make it fit?
Old 05-23-2019, 08:34 PM
Rocks are in the bucket, first picture
Old 05-23-2019, 08:46 PM
twoton twoton is offline
The new tank came from Yesterdays Tractors. I made the mistake of ordering one for a Ford 4000. I didn't realize that the Ford 4000 SU used a different tank. And, I guess they didn't either 'cause when I finally got someone on the 'phone yesterday they couldn't, with any certainty give me the correct tank number. They told me that I would have to call F/NH to get the number, which I did, and they had no idea... blah, blah blah...
I've used Kreem successfully to seal other tanks, like this;
https://www.onlycubcadets.net/forum/...593#post455593
...with great results, but.. it takes time to do it right, and I figured at a buck 25 for a new tank I'd just get a new one. Anyway...
Old 05-23-2019, 08:51 PM
The rocks were in the pile. Then they were in the bucket. Now they're in the tank.
I have to make the new tank fit... right back in the cardboard box that it came in!
Old 05-30-2019, 08:13 PM
I finally scraped away enough crud and paint to find the serial number;
D1414C
3D24B
*C378015*
D – Ford 4000
14 – Who knows? Maybe ‘Special Utility’
1 – diesel
4 – Independent 540 PTO
C – 8 speed manual trans
3 – 1973
D – April
24th day of the month
B – Day shift
C – Built in the good ol’ USA!
378015 – serial number
Old 06-07-2019, 08:00 PM
Time for a quick update.
After not being able to get a confirmation from Ford/New Holland as to the proper tank for this Ford 4000 SU I decided to take a chance and order the tank listed for a Model 3000, and guess what? Yup, it fits!
So, along with the new tank I installed a new fuel level sending unit, lock ring and sealing gasket. Also new fuel tap/shutoff,..and yes, there is a difference between the WIX filter that claims to be suitable for a CAV fuel system and the OEM filter.
Old 06-07-2019, 08:15 PM
The only difference between my new pump and the old one is the side cover plate. The original just had a blank plate but the new one has the provision for a return to filter line. Both it and the filter housing threads were 1/2 - 20, so I ordered a couple of SAE 5M x 1/4" NPTF adaptors ( I actually removed the o rings that came with the adaptors and replaced them with some copper washers that I had. ), a couple of 1/4" NPTM to compression fittings and some 1/4" steel line and plumbed the return line back to the filter housing.
That's it. New fuel system complete.
Old 06-07-2019, 09:20 PM
Tanks for the update, any other issues before you try to start it?
Old 06-07-2019, 10:11 PM
IHCubCadet147's Avatar
That’s coming along nicely, keep up the good work!
Tags
cav injector pump, ford 4000 su
