Old 06-08-2019, 08:03 AM
gabsgrammy54 gabsgrammy54 is offline
Default Kohler Courage SV590S, idle adjustment
I have a cub cadet riding lawn mower with a Kohler courage engine; Engine model number: SV590S and the spec number is: SV590-0220. Carb was leaking so I got a carburetor kit and installed it. Upon starting the mower it was running really erratically; high and low idling and very noisy. I’m trying to adjust the idle screws but the mower now won’t start unless I use starting fluid and it’s hard to keep it running to be able to adjust the screws. I looked at the service manual online and on one page it mentions something about a “governed idle speed adjustment (if equipped).” Does this engine have that? It also mentions the “low idle speed (RPM) adjustment”. Is this the adjustment I use? Do I need a tachometer make this adjustment or to read the RPM’s?
Old 06-08-2019, 08:40 AM
First,
Welcome to occ!
Just a guess here, but if the carb. worked correctly except for a leak,
and you installed a rebuild kit,and now it is not working as it should.
I would go back through your work looking for some mistake or an omitted adjustment.
in the service manual there should be settings for the idle screw mixture.
Most newer carbs have no high speed mixture screw but some have a solenoid
valve that needs power applied and it has to work properly.
possible the float is mis adjusted?
As far as the governor, most all carbs are controlled by a gov.so they respond to load and your selected throttle speed.
Old 04-25-2023, 12:26 PM
Help an ol lady Please Help an ol lady Please is offline
Default Idles low in high and idles too high in low how to adjust
I have a Kohler 19 Cub Cadet XTL 1040 and just replaced the carb and now it idles just right in high gear but idles way too fast, even faster than high gear in low. How do I fix this?
Old 04-25-2023, 01:29 PM
LAWN BOY's Avatar
LAWN BOY LAWN BOY is offline
Believe it or not I just fixed this same problem on my Kohler Courage this morning. You have to remove the hood and air cleaner assembly first. Yes, it is the low idle adjustment screw, simply turn it counter clockwise using a wrench or pliers, with the engine running, until it is sounding better. Before that though, check the condition of the fuel filter and air cleaner to make sure that they’re not the problem. Hope that helps.
Here’s a picture I took depicting the adjustment.
https://www.onlycubcadets.net/forum/...pictureid=8321
IH Cub Cadet 70 project, view my thread in the Kohler engines section for progress.
Old 04-26-2023, 10:11 PM
xcookpac xcookpac is offline
I have the same motor on my MTD lawn tractor. I had issues with the carb and replaced the carb with an el-cheapo Amazon carburetor. New carb fixed the old carb problems but created a new problem: surging at idle. Surging mid-throttle and surging full throttle. Fixed surging with replacement Kohler gasket (P/N: 20-041-18-S).
