#31
You moved the neutral adjustment bracket. That's the problem.
It's not in neutral any more with the brake pedal down. Put it up on jack stands. Bypass the brake pedal switch, move the speed lever while you try to start it. It will start. Hit the brake pedal and see where it is. It will be moving one way or the other. With it still running, adjust the neutral adjustment bracket as described previously.
All that should take about twice as much time as it took me to type this (I'm slow). And then you can positively address the hydro or coupling pins it that's where it's at. |
#34
An update....just started up....all is well...running fine for at least 10 minutes, although still a bit uneven - I suspect some carb adjustments are in order but would like to make sure the tractor won't move first before doing that. Anyway, I shut it off, restarted, still fine. Talked to the mechanic who built the engine - suggested possibly air locked in the system somewhere (?)
So now...shift lever is in neutral with tractor stationary, but then when I press the brake pedal down it wants to move in reverse. So back to jacking up, once again loosening the cam bracket and making minor adjustments - which is where I was yesterday till (whatever) started causing noises. Ironman..thanks...appreciate the detailed breakdown of everything. Tunnel cover has been off ever since yesterday. I type fast but work slow
#35
Appears I don't need to take out the shaft at this point...thanks though.
#36
No more noise....seems fine.....what remains is to do carb adjustment and get this neutral situation resolved so that I can press and lock the brake pedal down without the hydro wanting to go in reverse (yesterday it was forward) Good fortune has seemingly smiled upon me...
#39
Roundin' third and headed for home is a brown eyed handsome man!
https://www.youtube.com/watch?v=YqY7...t_radio=1&t=26 |
#40
You will be drinkin a cold one and sayin job done before ya know it!
