Old 06-12-2019, 10:47 AM
patrickjam3s patrickjam3s is offline
Default PTO mule drive belt
Hello all! I have a 104 with a 38" 3 spindle belly mower I've been trying to figure out what belt I need to go from the PTO to the mower deck.
I think I have it figured out but would like to confirm this is correct before I go buying belts.
I believe what I need is an IH-473462-R4 -3/8 X 81"
thanks guys!
Old 06-12-2019, 11:08 AM
That is what my list shows.
Old 06-12-2019, 11:32 AM
thank you
Old 06-13-2019, 08:16 PM
Steve N Mi Steve N Mi is offline
Do you have similar belt data for 50" and 60" decks on a Super?
Is the mule drive belt the same for the 50" and 60" decks?
Old 06-13-2019, 09:44 PM
I finally found this resource which may help
http://cubfaq.com/belts.html
Old 06-14-2019, 12:47 AM
Thank you. I'm not sure I will be able to use the two belts I just got thru Amazon, 1/2" X 86" and a 5/8" X 94" for my 50" deck. They are supposed to be replacement belts. The spindle belt number I got from Parts Tree and the mule drive belt was crossed back to a number on the old belt.
Still need numbers for the 60" deck.
Old 06-14-2019, 07:33 AM
Here you go
50" PTO belt 954-3006 tractor serial numbers 665,001-821,059
50" deck belt 954-3005
60" PTO belt 954-3023 tractor serial numbers 665,001-821,059 190-374 deck
60" deck belt 954-3052
60" PTO belt 954-3051A tractor serial numbers 821,060-899,000 190-325 deck
60 deck belt 954-3052
Old 06-14-2019, 04:41 PM
Thank you fellows. FAQ it is.
