Old 06-30-2019, 09:08 AM
Skinny's Avatar
Skinny Skinny is offline
Angry IH cub cadet 124
My belt for my PTO to my mower deck keeps jumping off. If I leave the tensioner loose or if I make it tight. When I put the belt back on with the tensioner backed off all the way the belt is still really tight. Is it the wrong belt, or am I just doing something wrong?
Old 06-30-2019, 09:36 AM
First, welcome to OCC............
Next, what mower deck (size or model) do you have ??
Lastly, what belt are you using ??
Old 06-30-2019, 09:50 AM
Skinny's Avatar
It’s a 421u111 the belt I couldn’t tell you it came with the tractor when I got it
It ran find then the guy I got it from dropped off the snow blade for it and we took the deck off so he could show me how to put it on and ever since then the belt just keeps come off
And how can I tell if I’m making the tensioner too tight
Old 06-30-2019, 10:01 AM
Is that mower deck a "bolt on" or a "quick attach"...??
This was at the transition point and could be either for the 124.
Old 06-30-2019, 10:05 AM
I believe the 2 pullies should align with each other to achieve proper tension.
If there is a weak or incorrect spring used for the QA this may be the issue here.
Old 06-30-2019, 10:10 AM
This should help you. Here is the Owner's Manual for the 42" Mower deck as found in our Technical Library Section..... Manual
Old 06-30-2019, 11:17 AM
Skinny's Avatar
It is a quick attachment set up and thanks for the manual I’ll read over it and give it a try
Old 07-06-2019, 06:44 AM
Skinny's Avatar
Does anyone know the part number for the belt so I can just order another one and see if that helps any
Old 07-06-2019, 07:54 AM
ironman's Avatar
ironman ironman is offline
In the Technical Library - Tractors, there is a belt chart....
https://www.onlycubcadets.net/forum/...ead.php?t=4633
Tags
belt, pto, slipping
