Old 07-06-2019, 04:36 PM
CubDieselFan's Avatar
Default 2284
Back when Diesel Doctor brought my 1572 back south, he also brought with him Dirty Steve’s 2284. It has been my main grass killer up until last week. Steve had trouble with it running bad, missing. I think it is the left side coil. I am in the process of converting the ignition from the ASam spark advance to regular ingnition, like is on a 1863/1864. Anyone ever done this to a 2284 or an engine with this system?
File Type: jpg E4A1D04F-AFD8-4FAC-9ED5-097673C8CA01.jpg (28.2 KB, 206 views)
Old 07-06-2019, 08:40 PM
IIRC I think the flywheel needs to be replaced unless you have the DSAM module. Maybe the Cyclops master will tune in.
Old 07-06-2019, 09:07 PM
Yes indeed, I have the kit with the flywheel and 2 coils. It even comes with the kill wire harness. I just wish I would have ordered a seal. This one has been seeping.
Steve gave me the link to the parts that the master gave him.
Old 07-07-2019, 08:55 AM
Dos this seal look like it is in too far?
File Type: jpg 02682708-6DFE-4AC7-ACED-FE590DF8CECB.jpg (32.7 KB, 177 views)
Old 07-07-2019, 09:23 AM
Looks OK to me.
Old 07-07-2019, 09:30 AM
Thanks Sam, for the picture. Seal should be here by the end of the work week.
Old 07-07-2019, 09:40 AM
I don't know if that kits comes with a wiring diagram but be sure you don't hook up the power feed for the SAM to the new mags or you will let the smoke out of the wires. The SAM should have a Red a White and a ground. You will need to use the white for your kill and remove the Red power feed. Here is the 2284 wiring diagram.
Old 07-07-2019, 10:33 AM
oh goodie,
more magic smoke potential!!!
so pretty on independence weekend.
Old 07-07-2019, 12:21 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
oh goodie,
They sell replacement smoke. Not sure if the Lucas is compatible with Kohler?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 07-08-2019, 09:10 PM
ccpullin ccpullin is offline
Just as a FYI, you are giving up 2 hp with the conversion.
