Old 07-14-2019, 06:52 PM
MBY852's Avatar
MBY852 MBY852 is offline
That is too cool! I like it!
Old 07-14-2019, 07:53 PM
Bum454ss Bum454ss is offline
They’re Hi-Run brand.. 23x10.50-12 The original tires were filled with coolant I think it was.. for additional weight. Four or five years ago the wheel actually sprung a leak from a rusted spot. So I cut the tires off because the bead was pretty much welded to the wheel. I had them sandblasted and repaired and then put the new rears on. At the time I just wanted to match what my grandfather had been using. I also have his Brinly plow and an eight disc harrow. Couple years ago I bought a push blade.. but I still need the blade sub frame for it.
Old 07-14-2019, 08:34 PM
MBY852's Avatar
Thanks for that info, appreciate it!
You have some nice equipment there your Grandfather left you. I look forward to getting out of Fl and heading northward where theres real dirt to put a garden in again.
Old 07-14-2019, 08:35 PM
three4rd three4rd is offline
Thanks.....thought it turned out pretty well
Old 07-14-2019, 08:41 PM
Mine still has a good amount of fluid in the one rear tire - had a new tire put on the left side a few years ago but the right still has whatever salt / water mixture they used. Tried to drain it out a few times but just wound up ruining an air chuck after forgetting to wash it off afterwards. So it can just stay in there until the tire needs to be changed. Often wondered why the rim hasn't rusted through as you mention.
Old 07-21-2019, 05:25 PM
IHscout79 IHscout79 is offline
Installed an electric lift on my Cub 147.
File Type: jpg D97AA00E-80C5-4C4A-9011-AF31ECF5A476.jpg (33.3 KB, 91 views)
Justin
Old 07-21-2019, 05:28 PM
Nice 147, and good job!
Old 07-21-2019, 05:58 PM
Thank you sir!
Justin
Old 07-21-2019, 08:31 PM
risinvillain risinvillain is offline
Default what I did to my cub today
Noticed a coolant leak on my #2 1572 diesel, I had already changed the water pump and thermostat, got lucky it was just a very original hose clamp that finally gave up, replaced it so far so good.
Old 07-26-2019, 02:14 PM
Joe from N.Y. Joe from N.Y. is offline
I finally put those AG tires on the back of my '67 124.
Its funny as the shade of yellow changes as i moved it around in the sun for photos.
