Old 07-23-2019, 12:42 PM
IHCubCadet147's Avatar
Originally Posted by sorner View Post
Looks good. Get ready for a party when trying to get those engine bolts in. I had a heck of a time with those ones through the cross member...
You’re invited to the party, I’ll let you put them in.
Some prefer to secure the cradle to engine, then set the assembly on the rubber mounts.
(put the snubbers on the cradle first, adjusting later)
You have room to maneuver/install the mounts that might fall off during install.
I found it easier that way, but others differ maybe.
Be careful threading into the aluminum pan if you decide to install the cradle first, they are easily cross threaded, not a happy ending.
I thought about that, it looked easier to to install the cradle first, we’ll see.
Originally Posted by twoton View Post
Blue lock tite on those oil pan bolts too.
Will do.
Looking good so far but did you put the snubbers on? I do not see them...
They are on, you just can’t see them in the picture.
Old 08-04-2019, 08:11 PM
I got it back together and took it for a ride. Everything seems good, so tomorrow I may put a deck on and cut some grass.
File Type: jpg 1B522CC1-5A58-48DA-8BC2-684E7A24354B.jpg (45.9 KB, 97 views)
Old 08-04-2019, 08:44 PM
sorner's Avatar
sorner sorner is offline
Looks good. Runs cooler too with the air duct probably.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
Old 08-05-2019, 10:21 PM
Thanks. The air duct made a big difference.
Old 08-06-2019, 10:44 AM
twoton twoton is offline
Good to see you're up and running.
Old 08-06-2019, 06:24 PM
Thanks!
