Old 09-01-2019, 11:32 AM
Rwgarrison23's Avatar
Rwgarrison23 Rwgarrison23 is offline
Default New Cub Cadet owner here. A few issues w/124.
Hello fellas! New here and new to antique cub cadets. I been looking for one for about 6 months and finally I found what I'm looking for. I bought a 1969 cub cadet 124. 12 hp kolher engine. It has a few issues but it does run.
Wiring issues is one of them and wiring to voltage regulator seem missing. Sometimes it wont start unless I wiggle some wires around. I need new key switch. I'd like to get it back to original as possible. It dies going up hill.
I have not went through the engine yet as far as spark plug, oil change, carb cleaning and fresh gas, etc. That's on the list.
Other than that, it seem like a solid tractor, original 1969 paint on it. The rear wheels, are they original or are they suppose to be in the upper 23 inches?
Old 09-01-2019, 11:46 AM
First, welcome to OCC.........
None of the tires are anywhere near original.
In the Tech Library Section on Page #5, is the Wiring Diagrams for the NF tractors. Download the one for your model.
I would replace the Ignition Switch and see where that takes you as far as electrical problems.
Old 09-01-2019, 12:16 PM
MBY852's Avatar
MBY852 MBY852 is offline
Welcome to OCC! Nice looking tractor. Good luck with her.
CC Model: 127 w/42" deck
CC/MTD Model: 2155 w/42" deck
.....DAD bought em new.....
Old 09-01-2019, 01:38 PM
Definitely tires is not original. The paint work seem to be original. I might be wrong tho as it is missing stripe along the hood.
Old 09-02-2019, 01:49 AM
Looks like a great cub cadet with lots of potential! Sometimes, the right one comes along and you just know it when you see it. If it was my cub cadet, I would go to the Technical Section of the forum and download the NF (narrow frame) wiring schemata for your cub cadet and then carefully trace out all of the wiring to make sure no Gremlins have overtaken it. Right away, your voltage regulator is unhooked from where it should be mounted (between the headlights). If you leave it on the heat shield and run your cub, then it will be toast real soon!!!
Old 09-02-2019, 10:11 AM
Off topic:
Nice Ghia had a '59, 40 years ago
Carry on with your cub discussion
Old 09-02-2019, 12:29 PM
The mounting ears is broken off. I have to buy a new regulator, unfortunately. The heat sheild is fubared too.
Old 09-02-2019, 01:37 PM
Billy-O's Avatar
Billy-O Billy-O is offline
If I were you, I'd think about replacing the wire harness: https://www.onlycubcadets.net/forum/...ad.php?t=34457
Nice tractor by the way!
Plow blade
#2 Cart
QA36 snowthower
Old 09-02-2019, 02:02 PM
Not a bad price for the harness! Better priced than anywhere else I seen.
Old 09-02-2019, 08:32 PM
Not only is it high quality but every single connection is labeled.
I purchased one for my 125 and it was easy to install.
Jeff
