Old 09-07-2019, 07:40 AM
Barcode Barcode is offline
Default Cub 124
I had to get a new voltage regulator And I cannot get this thing hooked up right on my new regulator there's an f post a battery post and L post any help would be great I have a yellow wire gray wire light blue wire
Old 09-07-2019, 07:49 AM
First, welcome to OCC............
Did you buy a Cub Cadet V/R or aftermarket ...??
The "L" is NOT used on a 124. It is to be insulated so it can't short out.
Old 09-07-2019, 07:51 AM
It's aftermarket
Old 09-07-2019, 07:53 AM
And there is a post on back side of v/r
Old 09-07-2019, 08:11 AM
So if L is not used how where do the 3 wies go
Old 09-07-2019, 08:43 AM
And my 124 has lights
Old 09-07-2019, 08:57 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Look at the wiring diagram for your 124..... https://www.onlycubcadets.net/forum/showthread.php?t=35
Make sure you have an compatible aftermarket. You are using B (Battery), G (Generator) and F (Field). The regulator must be properly grounded.
Plow blade
#2 Cart
QA36 snowthower
Old 09-07-2019, 09:12 AM
I have my gray wire hooked to battery yellow wire hook to field and green or blue wire hook to back of voltage regulator
Old 09-07-2019, 09:55 AM
I think I shorted out my voltage regulator are these able to be fixed
Old 09-07-2019, 10:25 AM
cooperino's Avatar
First get it hooked up correctly . If memory serves, Gray wire is BATT, Yellow is Field. Blue is Gen.
