Old 09-09-2019, 09:11 PM
IHCubCadet147's Avatar
IHCubCadet147 IHCubCadet147 is online now
Default Mower Deck Paint
I took the deck off my grandpa’s Husqvarna LT to clean and sharpen the blades. It is rotted pretty bad. What is a good paint to use on it that will not wear off too quickly?
File Type: jpg E4504873-4EF3-4730-BB87-C74B310CDE74.jpg (30.3 KB, 130 views)
Old 09-09-2019, 09:38 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Truck bed spray liner????
Plow blade
#2 Cart
QA36 snowthower
Old 09-10-2019, 06:47 AM
cooperino's Avatar
You might try a rust converter first then a Por 15 on top of that. Otherwise you could clean up and use some rusty metal primer from rustoleum.
Old 09-10-2019, 08:49 AM
Cub70's Avatar
Cub70 Cub70 is offline
Rustoleum Farm & Implement paint is great for this. You can get it at Tractor Supply. That is the paint I used on this deck:
1964 Cub Cadet 70 (Full Restoration), Upgraded/Rebuilt K181 8hp engine, custom exhaust stack/flapper, NEW clutch, brand NEW steering column, Custom made wiring harness w/ammeter, LED headlights and tail light, Custom 2” receiver hitch, Custom pull behind paint matched trailer
Old 09-10-2019, 09:20 AM
MBY852's Avatar
MBY852 MBY852 is offline
No matter what you put on will eventually wear off. When I worked construction and carried a diesel fuel tank in the back of the pickup it would leak all over the bed. Every fender, door and hood on that truck was rusted beyond belief but that truck bed was like new, not one rust hole in it. I've always cleaned the deck a few times a year and brushed or sprayed diesel fuel on it and never had a problem...
CC Model: 127 w/42" deck
CC/MTD Model: 2155 w/42" deck
.....DAD bought em new.....
Old 09-10-2019, 09:23 AM
MBY852's Avatar
Whatever you decide I would have it sandblasted and treat it accordingly after that....
Old 09-10-2019, 08:47 PM
Thanks for the replies. I think I’m going to use a rust converter then paint.
Old 09-11-2019, 08:39 AM
As said by others if the deck is used, it is going to get blasted by debris.
If one has sandy soil or bare spots, nothing is going to hold up.
oh and mulching dry leaves will clean up the underside of a deck like sandblasting it. BTDT
Old 09-11-2019, 08:45 AM
cooperino's Avatar
What he said! I usually paint the underside of my deck after my agrifab leaf sucker has sucked its last leaf of the fall.
Old 09-11-2019, 09:39 AM
If its really rotted like you say, sand blasting will more than likely leave you with a sieve
