Old 09-11-2019, 06:46 AM
Slyguysnype Slyguysnype is offline
Default Cub cadet 169 advice
Found this Cub Cadet. I heard there great tractors. Well anyways. $200 is it worth it. And what are somethings I should look out for when going to look at it. I'm good with small engines, just never worked on a Cub.
File Type: jpg PART95156815189412995IMG952019091095172501.jpg (22.2 KB, 136 views)
File Type: jpg PART95156815185430695IMG952019091095172435.jpg (24.2 KB, 138 views)
File Type: jpg PART95156815167625595IMG952019091095172417.jpg (20.3 KB, 136 views)
Old 09-11-2019, 07:18 AM
First, welcome to OCC...........
The 169 is a much sought after model. It was the first 16HP model they introduced. Plus, it is one of the rarest models, with only 4,005 units being made. Some had the infamous Kohler 13 Fin engine block.
$200 ??? In a heartbeat.
Old 09-11-2019, 07:21 AM
crazycubtrio crazycubtrio is offline
The tractor does not have the correct muffler for a 169. In fact if that angled style is on there the elbow was most likely changed as well. That would make me question further if the engine is really a 16hp or a 14hp with 16 tins. That being said if you are not a “ purist” a 14hp hydraulic, hydrostatic, beefy tractor with a 48” deck is still worth the asking price if it’s all there in my opinion.
Old 09-11-2019, 07:25 AM
Is there a way to tell?
Old 09-11-2019, 07:29 AM
And thanks for the welcome
Old 09-11-2019, 07:56 AM
cooperino's Avatar
It would be in my truck already for $200. It was not uncommon for exhaust to get changed to something other than factory. My question is why is the engine out of the tractor. Does it spin? Either way.. I would buy it!
Welcome BTW. Where in NY are ya? Downstate here Long Island
Old 09-11-2019, 08:00 AM
I would safely assume, it is the correct Kohler K341-71154 Engine in it.
The muffler is incorrect, in that the original IH-61274-C1 is no longer available from Cub Cadet. One can still find NOS or Aftermarket replacements.
There are about 3 different mufflers that will fit the 169, although not correct but will work. I am guessing this is the case.
The Blower Housing Shrouds are the same for both the 14HP and 16HP engines. The only way to positive to determine whether it is a 14HP or 16HP model, is to pull the head and measure the cylinder bore.
Old 09-11-2019, 08:05 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Mufflers are cheap to replace. Great deal!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 09-11-2019, 08:12 AM
Thanks for the info
Old 09-11-2019, 08:46 AM
modcub72's Avatar
modcub72 modcub72 is offline
14 h.p. has 9 head bolts, 16 h.p. has more.
