Old 10-22-2019, 08:33 AM
cooperino's Avatar
Originally Posted by Rwgarrison23 View Post
I wish mine would do that.
What does S/G means? My throttle sometimes have to be in the middle for it to start and sometimes choke doesnt do anything. I checked the float last night and it was very slightly off but I adjust it anyway. I'm going to put my original carb in a carburetor cleaner over night after taking it apart. Maybe it's the carb itself... but it runs pretty good once it fires up.
S/G starter/generator.
Deffinatly sounds like fuel issue
Choke not helping because your getting too much fuel
Old 10-22-2019, 08:39 AM
Rwgarrison23's Avatar
Rwgarrison23 Rwgarrison23 is offline
So, try lowering down the high side screw or the low side screw? What are the chances my S/G is not spinning fast enough?
Old 10-22-2019, 08:41 AM
cooperino's Avatar
I doubt the SG is the problem. Have you tried since adjusting float? I would try it with adjusted float first
Old 10-22-2019, 08:44 AM
I have last night, it was slightly off very little.
Old 10-22-2019, 09:16 AM
cooperino's Avatar
Off is off. If the filter was wet it was flooding. So how did it run after installing?
Old 10-22-2019, 11:04 AM
Runs the same.
Old 10-22-2019, 02:09 PM
cooperino's Avatar
Swap carbs and try it. You said before mixture screw did nothing right?
Old 10-22-2019, 02:11 PM
Right, it didnt seem to make a change at all no matter where that low side screw is set on. I'm taking it apart as we speak and letting it soak over night
Old 10-22-2019, 04:30 PM
So, as I was taking it apart and clean it, took the new carb off to compare stuff. I found the choke plate holes is different in size. Anything do with this?
Im going to put it back together and fire her up tonight and see how she does. Original carb is not that dirty but I blew through everything with my air compressor.
Old 10-22-2019, 05:38 PM
cooperino's Avatar
Choke plate would make no difference except for while choked. Perhaps it's incorrect carb? What part number carb did you get?
