Old 02-29-2020, 09:58 AM
John, you're a member of Cub Cyclops. In the files section is a service bulletin about slow reverse on the Cyclops. The bulletin was provided to me by Lew.
I have this one also Sam,
https://drive.google.com/file/d/1QjX...ew?usp=sharing
Up to 534 and counting...
Old 02-29-2020, 11:44 AM
Thank you Sir. Just sent you a PM
Old 02-29-2020, 12:24 PM
john hall's Avatar
So,, what do I have, a previous attempt at modifying? The 2 holes on mine actually intersect, kind of like a figure 8, but no where near being a slot.
I moved to the upper hole and readjust the bracket on the pump and the connecting rod several times. Finally the slot in the bracket is about even with the top of the bolt (not the flat washer referenced in service bulletin). Adjusted connecting rod. Looks like I have almost all movement in forward and lever is almost all the way up. Reverse appears to be just about full movement as well. Running it up in the air it looks tolerable. Addressing some other issues so hopefully I can get fenders on and give it a ride this afternoon.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 02-29-2020, 02:06 PM
The 2 holes seems to be common on later Cyclops, this was a 2182
Old 03-01-2020, 09:12 AM
farmall fred's Avatar
farmall fred farmall fred is offline
Hey Sam, can this still qualify as a Cyclops? It does have a single headlight!!!! It started out as a 2182 with a blown engine. Still has the Cyclops dash and tilt wheel. Not trying to hijack. I just could not resist.
Old 03-01-2020, 09:15 AM
Once a Cyclops, always a Cyclops. Nice work by the way, I'm impressed.
Old 03-02-2020, 09:22 AM
Thanks Sam. Now back to our regularly scheduled program.
