Old 03-01-2020, 12:27 PM
IHCubCadet147's Avatar
I would be very surprised that yammer did something like positive ground as it really screws with electronics.
And reversing polarity can let the "magic smoke out" of components rendering them non compliant
Here is a evil pray listing on used starters.
Does yours look like this after you reassembled it?
I'm still thinking you have the steel housing either end for end or 1/2 turn off.
But I have been wrong.
Listing number:
201663021577
Also google anything you can on wiring schematics/wiring diagrams for your sled if you haven't already.
EDIT:
look at the alignment marks in picture 5 (enlarge it) on the aluminum gear end housing where it mates to the steel field housing.
Verify you assembled it that way.
I found a diagram, it is hooked up right. That does look like my starter. I didn’t have the housing off, only the end cap. I’m going to double check everything later today.
Old 03-01-2020, 02:33 PM
Make sure you have the end cap orientation you had off, correct as it might affect rotation, but not sure.
prolly will if the end cap has the brushes in it prolly not if they are in the housing.
Best of luck, it is frustrating as hell
Old 03-01-2020, 02:45 PM
I’ll check it and let you know what I find.
Old 03-02-2020, 09:14 PM
My starter does not have the marks like the one in the link you posted. The parts can only fit one way, there are tabs that have to line up. I took the case off, that only fits one way too. I knocked one of the wires off the brush, I’ll have to get it soldered before I can do anymore testing. I’ll play with it again tomorrow.
Old 03-03-2020, 04:59 PM
I got it fixed. The case was 90* off, you have to line up the tab then twist it which I didn't realize at first. Not sure why it was off as I never took the case off, I must have done it without noticing.
Old 03-03-2020, 05:45 PM
Thank you for replying, glad we were able to help.
Hope you get the old yammer running well.
Old 03-03-2020, 09:59 PM
Thank you for the help. I put it back together tonight. It’s running good, I just have to adjust the choke cable and that should be all. Now we just need some snow, but it’s not looking like we’re going to get much more this year.
