Old 03-26-2020, 06:19 AM
AGillis AGillis is offline
Default Cub Cadet Lawn Sweeper left wheel not turning
I just purchased a very nice condition Cub Cadet lawn sweeper tag reads 193-366-100. Overall appearance is very good however there seems to be a mechanical issue with the sweeper. When pulling it forward the wheel on left side, when back is facing sweeper, does not turn. It locks up.
Any ideas whats causing this? And if so where do i get the part
Does anyone have a copy of the service manual for this unit?
Also is this a No. 1, 1A or 2.
Thanks
File Type: jpg A472096D-054E-49A0-8366-B08D176118F3.jpg (41.8 KB, 56 views)
File Type: jpg 00C62E6C-A2BC-449E-B7DD-7B99B7FA5AAC.jpg (44.4 KB, 54 views)
Old 03-26-2020, 06:35 AM
I would suggest pulling the LH wheel off. Sounds like the "racheting" mechanism is either dry or broken.
I would suggest or local Cub Cadet Dealer or the Internet.
These are Tiller model numbers.
Old 03-26-2020, 09:59 AM
ironman's Avatar
ironman ironman is offline
AGillis, I found a thread on another venue, the guy was looking for parts for your same model. He was advised that the sweeper was made by an outfit named Parker and it was a Model TE-7736. Here is the link that he was given for a parts drawing.....
https://www.jackssmallengines.com/Pa...er-TE-7736.pdf
Here is the link to the thread.....
https://www.ihcubcadet.com/threads/ih-lawn-sweeper.557/
Hope it helps you.
Old 03-27-2020, 06:33 AM
I removed both wheels, cleaned all the old grease, took off the engagement gears and found two roller bearings that must engage the propeller shaft. The left side was dry as a bone. Cleaned everything up and applied some waterproof grease, reassembled and all is well again.
Thanks for the advice
