Old 03-27-2020, 08:48 PM
Originally Posted by pinehillian View Post
took 2 outer shafts out, looks to me both top seals are in upside down, you can see the grove in rubber. with blade nut off i grease it and all grease only did top bearing and top of shaft. pulled shaft back out and bottom of shaft and bottom bearings completly dry. bottom seal looks correct, the flat side of seal is facing blade. old and new grease was acumulating under top dust cap with nothing in bottom, i will find new top seals next i guess, thanx
If I read your post right, it sounds like your seals are in wrong. The steel side of of the seal on the top seals should face up toward the pulleys. The bottom seals should face the same way.
But maybe I didn't read your post right?
Old 03-28-2020, 08:27 AM
pinehillian's Avatar
pinehillian pinehillian is offline
yes you read right, dont no why they were put like that. i think before the grease made its way to bottom bearing it squished out the top. i got to find part num to get new ones. my luck theres probly hundreds different ones. if i fix that and nothin i ll try adjusting the shaft down, see how goes it, thanx
Old 03-28-2020, 08:44 AM
https://www.partstree.com/models/324...and-pulleys-2/
https://www.ebay.com/p/2256580539?ii...SABEgJBvPD_BwE
I don't vouch for any of this stuff, just giving you a couple of leads.
Old 03-28-2020, 10:02 AM
ironman's Avatar
ironman ironman is online now
The book sez.....
Old 03-28-2020, 10:43 AM
Originally Posted by ironman View Post
The book sez.....
That instruction is what threw me off that I described in post #17. It's wrong.
Old 03-28-2020, 11:20 AM
them instr would be great if it tells you whether spindle is sitting on my bench or in the deck. seal facing up means facing blade if sitting on my bench and facing up towards bearing if installed in deck. im thinking either way 1 should be in backwards to let grease escape when pumped.
Old 03-28-2020, 11:27 AM
ironman's Avatar
I agree with you, just pointing out the error.
Old 03-28-2020, 11:30 AM
ironman's Avatar
I agree with you too. My preference would be that the grease not escape upwards under the pulley where it would splatter all over the place.
Old 03-28-2020, 11:52 AM
im thinkin rather have grease on the deck, if after all year cant be to much to wipe up but ya dont want globs on my lawn or customers lawns, nomatter 1 glob or 20 i will step in it, either way grease is still not gettin to bottom bearings
Old 03-28-2020, 06:52 PM
A little instruction sheet may help...
https://drive.google.com/open?id=14g...Lx6wn71vcsj0gT
This is for your SGT front mule drive.
https://drive.google.com/open?id=1Wa...QVr49WkYO67GBI
Up to 534 and counting...
