Alrighty! We are back in business. I got the PTO via FedEx on Friday and installed it Friday night (after I sprayed the package down with Lysol). I put it on, connected the wiring, torqued it down and did a quick test with the belt off. It worked!! Yay!
On Sun, I pulled it out and cut the grass so it is now in working condition again. One thing I did have happen, though, is if the engine isn't warmed up, engaging the PTO kills the engine (slows down, stutters, and dies before it can recover). I was able to pull the choke half out and that allowed it to successfully engage AND stay running. Once the motor is warm, it works without issue. I made some adjustments to the belt tension and it worked fantastic. I suspect its about time for a tune-up. In fact, its probably WAAAAY past time for one. About all I have ever done is change the oil over the years. Not sure what all I need to do to get it back to running in tip-top shape. Any suggestions? |
I have to up the idle when I engage the PTO on both my 1641 and my 2264 or it will kill the engine. The V-twins just don't seem to have the flywheel effect that they old horizontal twins had.
Also it is just good sense to not work a cold engine.
Treat a engine like one would a woman, warm her up and the results will always be much better
I had it at full throttle so that wasn't it.
True dat! But, it used to work fine. I guess its just like a woman in that respect as well - older she gets the longer it takes to warm up and be ready to go! LOL
