Old 04-08-2020, 09:41 PM
IHCubCadet147's Avatar
Good looking 72!
Old 04-09-2020, 07:35 PM
jbrewer's Avatar
jbrewer jbrewer is offline
I've learned not to take tight corners with my plug aerator behind the "O".... it's like trying to make a u turn with a spool hub.
Nice lawn and nice tractor and implements! I've never seen a plugger with a roller behind it...
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 04-11-2020, 06:39 AM
PACubs PACubs is offline
^ Thanks guys!
1968 Cub Cadet 72
Old 04-11-2020, 07:46 PM
Kristoffo Kristoffo is offline
Default Tenn. Cub 126
Took the blades off the 48" mower and sharpened them. Then mowed about 3/4 acre of blackberry canes. Yikes, not a fun job, but it sure looks better. I am amazed what this little guy can handle, 1" blackberries, pine and gum saplings, too! When I checked the belts both of them were in pretty bad shape. I want to get a backup set but I need to find the correct number for the 2 belts, the PTO belt has "IH 490489 R2" embossed on it, but I can't find anything on the spindle belt. Would appreciate any help in finding that number.
Have a great day on your cubs. ~ Chris
Old 04-11-2020, 08:55 PM
Check the parts look-up. There is a link at the top of this page. Type in your model number and choose the correct deck.
By the way, we love pictures.
Old 04-12-2020, 10:52 AM
RLemke's Avatar
RLemke RLemke is offline
Drained all the water and snot out of the rear end of the 1969 124 for the first fluid change since I’ve owned it. Made a new gasket out of a sheet of cork.
File Type: jpg 683FB663-C1A9-411D-9D1A-C96ED6B092FE.jpg (33.0 KB, 84 views)
Old 04-12-2020, 10:55 AM
RLemke's Avatar
Gasket making...
File Type: jpg D74A8714-2077-4436-A7F1-E3154F29E017.jpg (40.5 KB, 89 views)
Old 04-12-2020, 10:58 AM
RLemke's Avatar
It amazes me how clean the rear is after years of water sitting in it.
File Type: jpg 7CE2283E-AD6E-4607-9E3B-066333306040.jpg (19.9 KB, 84 views)
Old 04-12-2020, 11:06 AM
RLemke's Avatar
Added bonus, I don’t have to rock back and forth on the tractor anymore to get it to go into gear.
File Type: jpg DF4E32E1-9D3A-4F9A-BA5D-496A1866675E.jpg (22.4 KB, 235 views)
Old 04-12-2020, 04:55 PM
IHinIN IHinIN is offline
Pulled off the blade and chained turf tires and put on the ag tires. Need to hook up the disc and sow some more grass seed around the barn.
File Type: jpg FF70420F-E209-4F5C-8C8A-568E4668130C.jpg (40.5 KB, 229 views)
