Old 04-16-2020, 05:50 PM
ironman's Avatar
ironman ironman is offline
OK, then the only other diagram I can find is this one. It is as you describe. If you note part #2 is forward/reverse shaft. I have highlighted it in green. This shaft rotates whenever you press down the forward or reverse pedals. Highlighted in pink, is the same part but shown in 3 sections. It looks to me like the leftmost section (near #25 on the drawing) is the end that is shown and is designated "Control Cam" #6) in the Adjustments Section of the Service Manual.
Therefore it looks like the rod you are looking at is the only option that you have. Might as well give it a try, but I would suggest marking it somehow so you can put it back where it was if things don't work out. Good luck and let us know how it works out.
Old 04-18-2020, 08:14 AM
CubNewb CubNewb is offline
I adjusted it. Gives me a little more forward speed and a little less reverse speed. Also a hard stop when letting off reverse. Not creeping, but it costs to a stop a little when you lay off the forward pedal.
Will ride it a little this weekend and see how bbn I like it
