Old 04-23-2020, 10:16 AM
cooperino's Avatar
Originally Posted by rlriii13 View Post
As I parked my RZT after a quick spin on Monday, I did what I always do - I lowered the deck to the floor of my shed. But it dawned on me that I'm pulling on the lift assist spring when I put the deck down right? I've always stored my deck down because I have young kids and having it on the ground seemed better than having it elevated and them climbing all over it.
Am I going to wear out my spring faster by storing the deck all the way down? When you guys park, where do you set the deck?
Not sure it will wear it out any faster. I think of it this way tho. Springs only break while under tension. Garage door springs never break when the door is up.
Old 04-23-2020, 10:23 AM
rlriii13 rlriii13 is offline
Agreed. I think I'm going to make a change to how I park.
Old 04-24-2020, 03:14 AM
Steve N Mi Steve N Mi is offline
Tension springs may break in tension but compression springs (like the valve springs in auto engines) break in compression (no tension applied) and I suppose torsion springs by torsion. Except springs are subject to fatigue failure after so many load/unload cycles and I think fracture/separation can occur during the sudden unloading of a spring. My thoughts FWIW.
Old 04-24-2020, 09:35 AM
cooperino's Avatar
Originally Posted by Steve N Mi View Post
Tension springs may break in tension but compression springs (like the valve springs in auto engines) break in compression (no tension applied) FWIW.
Weather they are compressed or stretched... Any movement of this type of spring other than its relaxed state is likely when it will break. Compression is just the opposite force of tension. Still... there is force.
Old 05-12-2020, 07:37 PM
twoton twoton is offline
Nothing. I was too busy with the Ford's.
Old 05-13-2020, 11:04 PM
Went to end of the driveway to get the trash can. Taking my three helpers made it a bit more complicated.
Old 05-20-2020, 08:25 AM
3Kseries4ever 3Kseries4ever is offline
Default New front hubs and wheels for my Cub
I reworked the front spindles on my 3185 and installed 4on4 trailer hubs. Then bought custom 8" front rims. I like the look and the extra front end strength.
Bill
Old 05-23-2020, 06:33 PM
StudioDTK5 StudioDTK5 is offline
Default Planting Grass
I used the GTX2100 and 6284 to do a bit of yard work. The loader on the 6284 moved the dirt. The grader behind the GTX2100 leveled the ground.
File Type: jpg BE9952B1-0D9A-44A7-B5B6-855F0FF32C05.jpg (32.4 KB, 130 views)
Old 05-25-2020, 01:01 PM
SGragg SGragg is offline
Inactive Member
Still earning its keep. Gettin’ the yard mowed (1 acre) before the rain moves in on Memorial Day.
File Type: jpg 605D4AB3-C332-4765-A2E8-264E370F34C5.jpg (36.7 KB, 114 views)
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 05-30-2020, 10:33 PM
IHCubCadet147's Avatar
IHCubCadet147 IHCubCadet147 is online now
I pulled the herd outside to get some fresh air while I was sweeping their bay out. Ignore the red one, it snuck into the picture. It’s going to be getting a new home soon, possibly tomorrow.
File Type: jpg A73A4F01-16C9-4919-9868-B75606B706D8.jpg (43.3 KB, 87 views)
File Type: jpg DAEEC892-23D6-40D0-9DA1-B4FD62C54D42.jpg (43.3 KB, 87 views)
