Old 04-27-2020, 08:38 PM
Talking
Originally Posted by Rbertalotto View Post
Not sure how you could even think about doing this without a tire changing machine.
Like this
Monarch CK 12 lathe
Old 04-27-2020, 09:01 PM
Rbertalotto Rbertalotto is offline
Getting the old ones off was quite easy.....Putting the new ones on, especially the second beads...not so much!
Nice hammer....Been around the block a few times?...
Old 04-27-2020, 09:40 PM
BCDSFCRET BCDSFCRET is offline
Default Bcdsfcret
Get your self the small tire changer from Harbor Freight tools. I have one and it makes changing the small tires easy.
I made mine to mount into the receiver hitch of my truck.
Brian
Old 04-27-2020, 09:44 PM
going to look into that small changer......thanks
But I believe my biggest difficulty was doing this with inner tubes. Made it difficult for the bead to sit in the recess prioperly.
Old 04-28-2020, 12:17 AM
IHCubCadet147's Avatar
The tires look good! Now try mounting a set on freshly painted rims without scratching them.
Old 04-28-2020, 03:20 AM
TheSaturnV's Avatar
Red Dave....Yes, I might need to get that version if this "Hobby" really takes hold.....
What do you mean, "if."
Old 04-28-2020, 07:45 AM
cooperino's Avatar
Like this
Monarch CK 12 lathe
OK.. first time I have seen a lathe used as a tire machine. Not sure the bed on mine is deep enough. I've done some pretty small tires on my coats 10/10 however.
Old 04-28-2020, 09:06 AM
mickb72 mickb72 is offline
It helps if you warm them up in the oven first. Mike
Old 04-28-2020, 04:22 PM
gardenpest's Avatar
gardenpest gardenpest is offline
I was complaining to an elderly gentleman (76),lawn tractor repairman he is, about changing those little burgers on the front . He showed me his little trick and said work smarter not harder. The trick ....WD40 . Makes changing tires so much easier you'll want to throw nails in your driveway !
149..... qa-42 snow thrower..#1 tiller w/extentions, 109 w/deck, 129 w/blade 1450 w/deck
Case 444 gt.....H270 toro wheelhorse....Massey 135 diesel.....52 GMC
Old 04-28-2020, 05:39 PM
I used both a spray made especially for changing tires and a jar of Tire Changing Goo.....Both helped, but not enough!
