Old 05-01-2020, 01:27 AM
jdroison jdroison is offline
Default 1811 fuel pump
the fuel pump on the 1811 started leaking, this is the second time in 4 years. i bypassed it so i could finish mowing using gravity feed. I would like to put an electric pump on it, i have one from a 2182 i could use. is it a low enough pressure pump to work with my carb on the opposed twin 18.
Cub Cadets & IH tractors
1811 - 1090 hours
1872 basket case, rebuilding.
#1 tiller
1 Farmall regular
Old 05-01-2020, 07:10 AM
Sounds good.
Old 05-01-2020, 07:22 AM
Are you buying/doing something wong/wrong.
I've got pumps on those double breasted Kohlers that are 20+years old.
Where is it leaking, diaphragm? fuel into the crankcase? externally ?
Did it come loose and leaking engine oil?
Sometimes the needle valve leaks in the carb.and the fuel pump gets blamed.
BTDT
inquiring minds want to know.
Old 05-01-2020, 07:29 AM
The one on my 782 has been on the engine for 15+ yrs with no problem too.
Old 05-02-2020, 02:37 AM
first pump was original and started leaking into oil,i was lucky to catch it early. i had a used spare off of a bad engine so i installed it so i could get back to mowing. after a couple hours running this spring it started leaking fuel out the side of the pump body.
I just thought i would go electric to prevent any engine damage if i have one leak internally again.
1811 - 1090 hours
#1 tiller
1 Farmall regular
Old 05-02-2020, 09:25 AM
Advice?
electric will work if you want to go that way.
Me, I'd go genuine Kohler mechanical for a few bucks more.
They are made of plastic now (no corrosion)
and use an "O" ring instead of a gasket on the mounting.
You can sometimes find favorable prices on the 'net/ebay
Either will work. equally well, your choice.
