Old 05-07-2020, 11:34 AM
MrRazz MrRazz is offline
Default 1250 parasitic battery drain
It seems like i have somehow aquired a parasitic drain on my battery after doing some repairs. I had the fender pan and tunnel cover off to work on the hydro linkage and weld up the trunnion. Put it all back together and fired it up then it sat for a few days. Today the battery was lifeless. Jumped it and fired it up and noticed on the gauge that it continues to charge. Shut it off and the battery will slowly drain. If i disconnect the battery it will stop draining. I checked the red wire and there is no knicks in it on the entire length. Should i be looking at the regulator as the possible culprit?
Quietline 1250
Old 05-07-2020, 01:08 PM
Remove the battery cable,,
hook a 12V lightbulb between the battery, and the removed cable.
If there is a parasitic draw, the light will illuminate,
When you find the problem, the light will go out,,,
Old 05-07-2020, 04:57 PM
Not necessarily. I know i have a draw but its not enough to get my light going. Its a draw of .10v-.12v. I just noticed on the side of the motor it says to disconnect regulator while welding and fast charging. I welded my trunion and this started happening. So im guessing its my regulator unless someone can tell me something im not thinking if.
Quietline 1250
Old 05-07-2020, 05:43 PM
twoton twoton is offline
Roland lists a test procedure on page 5 of the Technical section - Tractors. Solid state charging system.
Old 05-07-2020, 05:55 PM
Wow ok so I deffinitely dont have a regulator that looks anything like that. The one i have on my 1250 looks more similar to the one on my 1970 chevy pickup.
Quietline 1250
Old 05-07-2020, 05:59 PM
Well not exactly but heres what i have
Quietline 1250
Old 05-07-2020, 06:07 PM
That's your starter relay, no?
Here's the one on my 1650. Should be the same as yours.
Old 05-07-2020, 06:14 PM
Yep my bad. I will test and see what i come up with.
Quietline 1250
Old 05-07-2020, 06:16 PM
Always a good idea to disconnect the battery when welding on a machine.
Old 05-07-2020, 07:34 PM
I had the battery completely out of it.
Quietline 1250
