Old 05-11-2020, 08:52 AM
three4rd three4rd is offline
Originally Posted by cooperino View Post
Yeah.. thats not the product I would have chosen. Once that sets up it can be a real bear to get it apart again. If you find that the pinhole is leaking there are several different ways to repair it.
Coop...curious about repairing the pinhole. If need be, what would you suggest? Hopefully, as I said, it doesn't go all the way through the tank. Kind of wish now I would have gone with the Oatey tape, since, at least based on the visible portions of the threads, there appears to be no way to even know if this sealant is setting up.
Old 05-11-2020, 09:03 AM
cooperino's Avatar
There are several methods.. One would be to braise weld.. I would not suggest this unless you know the safety procedures in welding a gas tank. Another way is epoxy or patch made for gasoline tanks. JB weld makes a pretty good 2 part epoxy, There is also one called "seal all" that I have used.
Old 05-11-2020, 10:06 AM
Didn't think of JB Weld. I have some of that. Might as well put some on as a precaution. Easiest to do while the tank is off the tractor anyway. Thanks...
Old 05-11-2020, 01:30 PM
cooperino's Avatar
It has to be JB weld specifically for gas tanks.
