Old 05-21-2020, 12:00 PM
mik125 mik125 is offline
Thanks Darkminion, that did it.
I got rid of those washers. The only thing holding the pulley on now is a flat washer on top and the zerk bolt. It spins freely when tightened down and I have the deck on the tractor again!
Last question and then I have some cutting to do.... do I need a lock washer in addition to the flat white washer under the zerk bolt?
As for the additional hardware, the only thing I can think off is they were added to compensate for the worn pulley. The notch on that pulley was worn out and maybe the guy needed those extra washers to keep it as tight as possible?
Old 05-21-2020, 09:04 PM
I would put one on, but the star washer would be betterer.
Old 05-22-2020, 02:49 PM
ironman's Avatar
ironman ironman is offline
This is how mine exist. The pulley sits directly on the shoulder of the spindle. However, I have had some where I added a thin washer there to raise the pulley because the pulley was rubbing the deck or the bolt heads that hold the spindle housing to the deck. No lock washer on the zerk bolt although I don't know what it would hurt.
Old 05-23-2020, 03:44 PM
Thanks for the photos ironman. I did some mowing today with the IH 48" deck with hydro lift... its real smooth and quiet in comparison to my sears mtd mower........and 40+ years older too! Thanks again.
