Old 06-09-2020, 10:12 PM
dale c. dale c. is offline
pull the right valve cover and see if it has both valves moving up and down . it might have had a push rod jump out of place . the bolts that hold the rocker arms down might have stripped the threads out of the head
Old 06-12-2020, 02:42 PM
joel1987 joel1987 is offline
Was able to compression test it today left side was 175 right side 155. But I don’t have the experience to determine what this test indicates.
Old 06-12-2020, 02:47 PM
Also pulled the valve cover and both are moving freely
Old 06-12-2020, 05:15 PM
CubDieselFan's Avatar
Originally Posted by joel1987 View Post
Both sides are getting spark. However while it is running if I pull the right spark plug nothing changes. If I pull the left plug it shuts the mower off.
Sounds like you have a weak coil on the right side. I had a weak coil in a 2084. Doing similar to what you are describing.
Old 06-12-2020, 06:11 PM
dbuck dbuck is offline
Talking
Reveals condition of your valves, valve seats, and piston rings. It sounds to me that the right side cylinder is not wearing equally to the other. I would do a leak down test.
Old 06-13-2020, 03:21 PM
Well I replaced the ignition coil for the right side today which solved the problem! Thanks for all of the help.
Old 06-13-2020, 07:50 PM
I like happy endings.
Old 06-13-2020, 10:47 PM
Billy-O's Avatar
Billy-O Billy-O is offline
[QUOTE=Sam Mac;498015]I like happy endings. [/QUOTE
Me too!
Plow blade
#2 Cart
QA36 snowthower
Old 12-15-2020, 10:17 PM
curtm's Avatar
curtm curtm is offline
Default leakdown test would be a whole more accurate
could be broken rings or a valve problem, leakdown test tells all
Curt
