Old 06-16-2020, 03:29 PM
B440? B440? is offline
Default Command CH18 Oil Past Breather Gasket
My Command V-twin is blowing oil past a brand new gasket for the breather cover. I've isolated it to the oil pressure switch oil galley. I plugged off the pressure switch hole to eliminate that variable. breather hole area is not the problem, Flapper on breather verified working.
It seems that the pressure is too high? when cranking the engine, I can see where oil comes in through one hole, but I don't know if it drains out? I see other holes, but the oil doesn't drain back.
Can anyone verify where the oil passages go for the oil pressure switch? Someone said "replace the breather cover and gasket as a kit and all will be fixed." <-- any truth to that, or do I have a blocked passage?
Old 06-18-2020, 06:01 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
if the oil galley had a drain there would be no oil psi
scan in the QR code (upper left) or text IHCC to 51660 to follow which shows and pulls we will be attending.
Old 06-18-2020, 09:47 PM
If there was no drain, then how would you change the oil that gets into it?
I will clarify; which holes slowly drain off oil when the machine is shut off?
Old 06-18-2020, 10:01 PM
I think you are using improper terminology.
There are oil passages for lubrication that work under oil pump pressure,
then there are crankcase areas that there is no pressure relatively speaking
and are vented to outside or intake manifold for emission reasons.
Old 06-19-2020, 07:10 AM
This is the breather for a CH
Old 06-19-2020, 07:31 AM
I highlighted the area in red, which supplies oil to the item circled in red.
Old 06-19-2020, 10:40 AM
I suspect you have a positive crankcase pressure instead of a slight negative pressure and it is forcing the oil out.
Worn piston rings, blown head gasket, leaking crankshaft seals, leaking dip stick seal?
Or maybe I don't understand what you are talking about?
Old 06-19-2020, 10:58 AM
The breather valve is operating correctly. The breather cover deals with two separate parts; breather valve, and oil pressure switch. The OPS has a passage where oil is pumped up to it by the oil pump.
Extra info: All new head gaskets on the engine, new shaft seals, no visible leaks in those areas.
So I'm going to try the new cover/gasket and spin the oil pump. If it still leaks, then I need to open the block up, find those passages and see what's blocked.
Old 06-19-2020, 02:27 PM
TomRom's Avatar
TomRom TomRom is offline
Wouldn't a blown head gasket, leaking crankshaft seals, or leaking dip stick seal vent pressure not build it?
IHCC - 122, 125 x2, 127, 108 x2, 129, 149 x2, 1200, 1250, 1650 x2. SEARS - Six Speed Suburban 10HP, Quick Speed Change Suburban 10HP, Six Speed GT18 Twin. ECONOMY - Country Squire. CASE - 580B CK tlb. That's it for the 4 wheel ones....
Old 06-19-2020, 06:56 PM
Yes,
but thinking it is a OHV( not familar) and if the head gasket leaks into a crankcase area where the pushrod gallery is, it is possible to push compression into it.
(again not familar unless I do some research and i'm too lazy)
