Old 06-19-2020, 09:55 PM
TomRom's Avatar
TomRom TomRom is offline
I think you did a great job, if you had a lathe it would be perfect.
Unless it's a gawd awful noise I would not worry too much about it. There is so much old loose metal on the old cubs could even be a loose hood hinge pin. I think of the old cubs a lot like my Harley, they just make noise. But both just keep on going.
IHCC - 122, 125 x2, 127, 108 x2, 129, 149 x2, 1200, 1250, 1650 x2. SEARS - Six Speed Suburban 10HP, Quick Speed Change Suburban 10HP, Six Speed GT18 Twin. ECONOMY - Country Squire. CASE - 580B CK tlb. That's it for the 4 wheel ones....
Old 06-20-2020, 09:25 AM
IHCubCadet147's Avatar
Originally Posted by Vrobert View Post
Bummer though, it sounds like I have a 'knock' but I'm not sure.
Check the transaxle mounting bolts, 3 on each side. They were loose on my 129 when I got it, allowing the trans to move, and it would knock going into neutral. I tightened them up and it has been fine ever since.
