Old 06-27-2020, 03:45 PM
hogfly hogfly is offline
Default 1863 hydro leak
hello all my dads 1863 started leaking hydro fluid really bad found leak under gas tank support on the 2 90 degree lines that are flared on the 90s that thread in the case part #727-3068 blowing up line from flare nut tryed to tighten it up no luck took it off cant see nothing wrong doped it up reinstalled still leaking any suggestions thanks kenny
Old 06-27-2020, 04:56 PM
CubDieselFan's Avatar
Are the rear bolts tight? I just bought a 2082 that was leaking at one of 90 degree bends at the pump output. The rear bolts were loose and this cause the line to fail.
Old 06-27-2020, 05:13 PM
garydee's Avatar
garydee garydee is offline
Default Hydro leak
Check to see if the "0" rings on the 90 degree fittings that thread into the case are damaged...this could be the source of the leak...
Old 06-27-2020, 05:16 PM
its not here this one is leaking from the flare connection i do hvac thought maybe the flare cracked but cant see any problems wish it was here but its at my dads house do you think just replace lines was hoping just a leak not some kind of back pressure or something spraying oil just seems weird but not sure about hydros never worked on them thanks kenny
Old 06-27-2020, 05:23 PM
its not the end with the oring to case its the flare nut spraying out the top thanks kenny
Old 06-27-2020, 06:06 PM
I've fixed several. This is often caused by the hydro bolts coming loose at the frame and letting the transmission move up/down. Causes flare fractures. I changed the line on my first one. Re-flared existing lines on the next two.
This may or may not apply to your situation but yours sounds the same as mine. This sometimes lets the cooling fan hit the lines.
Old 06-27-2020, 06:33 PM
i did reflare it but i will get dad to check bolts thanks
Old 06-27-2020, 07:38 PM
Just got done fixing an oil leak on a 1641, turned out to be the relief valve. This is the second 1641 that I've seen leaking from this valve. New O-ring and all good.
Old 06-28-2020, 10:07 AM
his is leaking from top of that nut in bottom right corner of pic spraying and i cant see nothing wrong should i just try new lines thanks kenny
Old 07-01-2020, 05:01 PM
ok guys thanks for your help turned out every single bolt was loose ordered both lines and orings hope this takes care of it again thanks all
