Old 06-18-2018, 07:57 PM
twotallkris34 twotallkris34 is offline
Default K301 Getting Red hot
I have a cub cadet 122 with a k301 in it, the motor is getting super hot, the fuel in the tank is boiling. I have no Idea where to start with this issue any help would be appreciated.
Old 06-18-2018, 08:34 PM
Pull the engine and take the tins off.
Clean the motor.
Pull the head gasket and decarbon the head and combustion chamber.
Plane the head.
Install new head gasket.
Adjust the valves.
File the points and set the timing. (Do not just gap the points.... SET THE TIMING.)
Clean or install a new spark plug.
Check ignition coil terminal and plug wire for corrosion.
Clean or replace as necessary.
Clean fuel system, including the inside of the (removed) carb.
Reinstall the carb and tune it. DO NOT just use the preliminary settings as stated by the book. Set it to those specs, then tune as needed.
Should fix you right up. Unless you find out the motor is shot once you get the head off....
Old 06-18-2018, 09:55 PM
Bamafan Bamafan is offline
Inactive Member
Clean the motor.
Plane the head.
Adjust the valves.
J-mach you are on the ball tonight. You must have had a good day or night.
[B]Larry[/B]
Old 06-19-2018, 12:01 AM
Clean the motor.
Plane the head.
Adjust the valves.
AND, DON'T skip any of the above procedures...
Old 06-19-2018, 08:35 AM
Thanks Guys, Looks like I have my work cut out for me !
Old 06-19-2018, 08:57 AM
Here's some videos to help you on your way.
https://youtu.be/L1jFtTzLh7o
https://youtu.be/VrVmag-layM
https://youtu.be/iuD8pzCe6aE
Old 07-30-2018, 09:55 AM
Old tractor guy Old tractor guy is offline
Default R ed hot cub
Be sure that it dosen't have a aluminium breaker plunger rod make sure that it is steel, i had that problem years ago,kohler brought that to my attention replaced that and problem was solved.
Old 07-30-2018, 10:29 AM
Lots of aluminum ones out there still. Not that big a deal.
Old 07-15-2020, 04:43 PM
greg r greg r is offline
My experience with run hot air cooled engines are 1) blocked air flow 2) late timing. All those steps will cover you well.
Old 07-15-2020, 07:19 PM
Ummm
2 year old thread??
