Old 07-27-2020, 02:43 PM
eberner's Avatar
eberner eberner is offline
Default Stupid Question for a 127
I know this is a stupid question, but is the Tunnel that mounts to the frame that the Dash tower bolts to welded in place?
Old 07-27-2020, 02:49 PM
Billy-O's Avatar
Billy-O Billy-O is online now
127 is a narrow frame and, yes, the tunnel is welded in place.
Plow blade
#2 Cart
QA36 snowthower
Old 07-27-2020, 03:25 PM
eberner's Avatar
Thats not funny, all the important stuff is under there (Hydro valves, drive shaft, etc.)
Thinking I may hsve to kock it loose and reinstall it with bolts. Its on jack stands now and mostly stripped down for a repaint/refresh. replacing anything I find thats worn out or broken.
Having that tunnel out of the way would make the process so much easier.
Any thoughts?
Old 07-27-2020, 04:35 PM
mortten mortten is offline
Part of the joy of narrow frame ownership.
Doug
QA-36A
42" blade
Old 07-27-2020, 04:42 PM
Thinking I may have to knock it loose and reinstall it with bolts.
Some people do.
Old 07-27-2020, 07:34 PM
Billy-O's Avatar
Honestly, pulling the rear is not that big a deal. Once you know what to do, you can have the tractor split in less than 1/2 hour.....like I can!
Plow blade
#2 Cart
QA36 snowthower
Old 07-27-2020, 08:37 PM
Yeah it's not bad. It's part of the joys of a narrow frame owner...plus how often do you really need the tunnel removed anyway? Should be nearly never.
Old 07-27-2020, 09:42 PM
IHCubCadet147's Avatar
Pull the rear, fix what needs to be fixed, and you shouldn’t have to worry about it for a few decades. Not a bad job.
Old 07-27-2020, 11:17 PM
TheSaturnV's Avatar
How would you "knock loose" the tunnel, which is essentially a huge part of the frame. It basically falls apart with that removed.
I can see how you could cut a notch towards the trailing edge to gain better access to the plates and hydro valves. I briefly considered doing that and putting the piece back in with a hinge, but ultimately didn't want to hack up an old classic.
Old 07-28-2020, 12:28 AM
I kinda have to disagree about these comments,,
With a SERIOUSLY used 149,, (not a garage queen, a weekly mowing machine,, etc,,) unless EVERY component is replaced,, and I mean EVERY component,, That tunnel cover has to come off at LEAST annually.
There is gonna be some issue with a machine of this age,,
Heck, I even tossed the four screws that held the cover on,, and switched to "sprung" cotter pins to hold the cover in place.
The cotter pins had the legs spread slightly, you would squeeze the legs, and insert the cotter pin, the head was big enough to not fall through.
Forward / reverse friction, the fan, relief valves, drive shaft components,,
THEN there was the accumulated dirt on the transmission that needs washed,,
pull the cover, PULL THE COVER,,, PULL THE COVER!! - .
Pulling the cover off the 149, then pulling the cover off the 1872,, THAT was the reason I switched to a gear drive machine,,,
