Old 12-04-2010, 06:03 PM
Thanks Jeff!
Great pics, guys! You've been busy!
Old 12-04-2010, 07:26 PM
Nice pictures JayBrd
Old 12-05-2010, 08:27 PM
Sminkey
Guest
Posts: n/a
Default No snow so...
I'm bummin some, was supposed to get 4-8" of snow and got about 1/4". But up the road 10 minutes there's 6". So I got into the engine on the 124 tonight, took the carb off and apart to clean and rebuild. Found out why it got parked, the teaser spring is broken/smashed and looks like the clutch release lever is adjusted all the way in.
Old 12-05-2010, 09:27 PM
Thanks for the update pics, Jude!
Old 12-05-2010, 10:59 PM
Sminkey
Guest
Posts: n/a
Thanks Wild Bill! I have exactly what you pictured:biggrin2.gif:. And I also use a dremel to clean things up after. The tip about the stones was a good one, will do that as I'm starting to accumulate some crud on the bottom. That stuff is strong and works very well, It was one of the 1st things I bought when I got my 1st cub.
Old 12-05-2010, 11:08 PM
Just don't leave the carb in there any longer than you have to...it will eat the entire thing eventually if you do. In warm weather, a couple of hours in there is plenty.
Old 12-05-2010, 11:56 PM
A few hours has always been enough for mine. The paint falls off and everything looks shiny. My point is, don't forget it's in there...
Old 12-06-2010, 10:59 AM
juniors1282's Avatar
Good old lake affect snow got about 6" so far with the potential for 8" to 12" more tonight and tomorrow. I'd say it's coming down at about an inch and half an hour right now. Looks like I'll be getting alot more seat time in the next 48 hours, Darn the bad luck!!! The new "O" did a great job and I don't have the weights on yet going to do that today. Hope you guys wishing for snow get a little, got my fingers crossed for ya Jude.
1966 IH cub cadet 102x2
Old 12-06-2010, 11:07 AM
squatch squatch is offline
That carb cleaner above will remove the gold color off a Holley carb if left in it overnight. I found this out the hard way.
Old 12-06-2010, 12:36 PM
cubs-n-bxrs's Avatar
I forgot and left a dissembled carb in the exact same cleaner for well over a month this past summer and nothing got eaten. Maybe you got a hopped up batch or something. If it isn't a carb that I need immediately I usually let them soak for a week or so. Been using the gunk brand carb cleaner for 25 yrs and the only thing I found it is hard on is seals and o-rings.
