Old 08-21-2020, 02:21 PM
Default Carter Carbs.
Hey All. Decided to rebuild the Carbs on the 124 and 125 both with k301AS engines and Carter carbs. When I did the first one I opened the rebuild kit and there was no seat in the needle seat assembly. There was needle and brass screw in part of the seat, but no seat. The one took apart certainly had a rubber seat just where you would think it should be. Called company that sold the parts and they said "It seems like there should be one but their rebuild kit did not contain one"? Well hmm, Went ahead and did the rebuild with all else and got it running pretty well. Left the old seat.
Did the second one today, when I took it apart there was no seat for the needle in the bottom of the brass part the needle sits in. My assumption was there should be seat because I have never been in a carb without one. First Carter Carb I have been in however.
The kits also had no gaskets for the intake or the air cleaner mount. Who makes kits that have all the parts? Or does stuff have to be ordered in pieces instead of a kit. Thanks
Ken
Old 08-21-2020, 02:48 PM
What Kit(s) did you get ??
Old 08-21-2020, 03:25 PM
Kohler Parts 25 757 01-S
Ken
Old 08-21-2020, 03:38 PM
This is what is in the Kohler Carb Kit 25-757-01-S
Old 08-21-2020, 05:26 PM
I know what's in the kit. Am trying to figure out if indeed there is a
seat that belongs there. Maybe I wasn't real clear in my original
question. In the assemblies on the parts blowups it lists a #18 needle
seat with the same kit # we are looking at. I guess I have always
gotten the parts I needed for a carb when I ordered a carb repair kit.
Ken
Old 08-22-2020, 08:39 AM
mortten mortten is offline
Don’t think Ive ever seen a Carter carb for a Kohler engine with a rubber seat. None of the six or seven I have around here have them. Carbs on Tecumseh have rubber seats in them.
Doug
QA-36A
42" blade
Old 08-22-2020, 09:00 AM
Thanks Doug, that's what I have been trying to figure out. Wouldn't have
been so puzzling if the first one I opened up hadn't had a rubber seat
in it. PO attempt at something I reckon. Thanks again
Ken
Old 08-22-2020, 10:52 AM
Thumbs up
Yep I bought the genuine Kohler Parts. When talking to the company on the
phone they didn't even know what the inside of the carb looked like to
help me out. Just trying to put em back together the way the manufacturer
intended. A bit of challenge it seems. Thanks for the help.
Ken
Old 08-22-2020, 11:36 AM
Usually a Carter carb had a viton tipped needle(it feels like a rubber tip) and a brass receiver that the needle lives in, and is threaded into the carb body. Some early carbs used only a metal needle with a brass seat. Other manufactures as mentioned, used a metal or aluminum needle but the brass receiver/seat where the needle lives used a neoprene or viton sealing seat that looked like a disc or "O" ring that the needle seated in, still others had the needle seat pushed into the carb base and some were not replaceable.
Back in the day pre 60's, it was common in most carbs for a needle to be steel and the seat/receiver it lives in, was brass and screwed into the body. With the advent of the viton tip needle, better sealing was accomplished and less fuel leaking into the carb/engine both during operation and storage.
Hope this helps.
Old 08-22-2020, 03:14 PM
It think his concern was that someone previously put some kind of rubber seat in his carb that didn’t belong there. He thought the kit should have had the rubber piece to replace but since it is t supposed to be there, the kit did not provide one.
Doug
QA-36A
42" blade
