Old 12-23-2020, 12:58 PM
Cubcadet_107's Avatar
That is indeed the correct spot from what I could find. They do sell the proper push-pull switches, I saw a few of them when I looked it up.
'70 107 with k301 engine swap
'71 106 with 38" deck
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 12-23-2020, 01:53 PM
CubbyRI CubbyRI is offline
thanks! where did u see those?
Model 100 Dec 2020 - Running condition, has snow plow!
Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one
Model 100 Feb 2019 apart for total frame-off / sandblast etc resto
Model 70 Sep 2020 needs total resto and an engine, or for parts
Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts.
two spare hydro rears
"in for a penny, in for a pound!"
Old 12-23-2020, 06:09 PM
Seems the only good lead I could find was from CC Specialties, $56 is a lot more than I expected for one but they are there.
https://www.ccspecialties.org/electrical.html
You'll have to scroll down quite a bit to find them
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 12-23-2020, 06:30 PM
$56? Ok it's the marine pull switch then and I can turn a more correct knob on the lathe.
Dumb question, this tractor has a key that is ON when turned left. Right is OFF. BUT, the key only can be removed out when it's on.
Think it's faulty? Is it original?
Old 12-23-2020, 06:45 PM
I would send a switch to ya if I could figure out how to get it off the parts machine...
Something is definitely off with that switch. If you can only remove the key when it's in the On position, somethings definitely not right. Probably best to get that replaced.
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 12-23-2020, 08:04 PM
appreciate that thought 107!
I'll dig one up. I think these must have had had a only OFF-ON (no start no accessory) switch.
Be nice to find an off-on-accessory one with no starter position so the lights cant be left on. But probably dont make them like that. Of course the Start position could be used for a horn LOL
Old 12-23-2020, 08:19 PM
Hey look what I found and ordered! Batt/Ign/Accessory (no start)
Old 12-23-2020, 09:09 PM
Pretty cool, but I liked that idea of using an off/on/start switch for a horn!
I do believe that with the stock light setup the lights would remain on even when the engine isn't running, the cubs are too old for anything fancy to keep the lights off when the engine is off. Even so, it'll be pretty slick to have lights without the stock light switch
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 12-23-2020, 09:14 PM
Oh I just meant the lights would be on ACC (and ON) position, so even if I left the light switch on, turning the key off would also kill the lights. I wouldnt want them to come on with the key because need that power to start the engine.
BTW really havent found a "good" U1 size battery (except maybe an Odyssey for $$$). Thats why since the 123 needs the battery tray redone, I'll make it a car battery size and can run an AGM.
This 100 got a "Traveller" battery from TSC for $45 with 90 day warranty, hope it holds up!
Old 12-23-2020, 09:25 PM
Now that makes sense. If you left those lights on overnight your battery would be completely dead. I actually left my 106's light on overnight once and she still fired up no problem (but like I said before, my LED lights draw a LOT less power).
For batteries, my 106 and 107 both run a Walmart brand "Everstart" Lawn and Garden battery, with 350 CCA's. Biggest Lawn and Garden battery that Walmart's got. They seem to work fine unless you leave them half-charged and it gets real cold.
I did some service a couple weeks ago to the 107 that involved cranking it over a bunch but not starting it, leaving the battery not fully charged. Then the cold hit it and killed it.
Swapped it out with a smaller 230 CCA battery of the same brand that was fully charged and despite the less power she still fired right up. And even after sitting a few days in the coldish weather, I went out tonight and that same battery still had good charge.
But if there's ever one thing I'll never understand about batteries, it's the warranties...
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
