Old 12-03-2020, 07:08 PM
Goofus's Avatar
Goofus Goofus is offline
Default Hello from Owego, NY!!
Just picked up a well-neglected 127 the end of the summer and have been working on rehab. Will add a picture when I can get out of work before sunset one of these days.
So far:
- All around new tires (prior owner had them all around 50 psi, kinda did them in) including Ag rears and chains.
- Plug, oil, filters, belts, grease, etc.
- Added home-cobbled headlights and tail-lights for the plowing season
- Working on correcting the wiring. Always reads discharging even when my meter says it's charging. Connectors and wire insulation breaking down.
- Retrofit the plow from my other tractor.
- Brake work, more to do still.
Will post more as progress is made.
Old 12-03-2020, 07:21 PM
Cubcadet_107's Avatar
Good to have another Narrow frame owner, they are great tractors and once you get it all serviced and running good, with routine maintenance, it will last longer than you live! My personal favorite series is the 1X6 and 1X7 series, which the 127 is from. Also, there's nothing wrong with home-cobbled headlights, both my 106 and 107 have them. Didn't drill any holes or anything to mount them up.
Keep us posted, and around here, we like pictures
To the left is the 107, with it's custom dual round lights. Simply mounted to a piece of cut aluminum, bent to fit in a small slot just beneath the battery box. To the right, the 106 with it's single rectangle light bar on the front grille. Both LED's, provide lots of bright light with barely any battery drain. (in the 2nd pic the tractors are on opposite sides of the first, but that's the only pic I have with the lights on). I'm interested to see your lights
'70 107 with k301 engine swap
'71 106 with 38" deck
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 12-03-2020, 10:20 PM
longislandcubs longislandcubs is offline
Welcome to OCC.
Old 12-04-2020, 07:54 AM
Welcome to OCC.........
Old 12-22-2020, 04:59 PM
Goofus's Avatar
Default So, here are some pictures
Here are some pictures of my Cub so far, just after clearing 46!!!! inches of snow on its maiden plowing journey. Working on some weights for future work as my 280lbs of dead weight was barely enough to get through this job.
This old beast is awesome, can't imagine what it'll be like when it's fixed up!!
You can see the LED headlights on the front, the LEDs in the rear are mounted in holes that I drilled in the reflectors. Working on a more permanent solution for the tails but the heads work great as-is. Perfect ugliness!!
Old 12-30-2020, 12:14 AM
Riley Henderson's Avatar
Riley Henderson Riley Henderson is offline
That's a nice looking 127! I would be tempted to just keep it cleaned up. They make new wire harness that look close to the original style. I know wiring is a very common problem on that series.
IH cub cadets 800x3,1000,1100,1200x2,1250DS,1450,1650DS, 71,122x2,123, 73x2,106,107,126x3,127,147x2,86x3,128,149, 169x2 ,Original, cadet 55, to name a few
CCC machines
1282,1050,2072,1535,1440
Old 12-30-2020, 10:42 AM
SGragg SGragg is offline
Inactive Member
I reckon if it can handle that load of snow, it'll handle about anything. Nice 127!
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 12-30-2020, 12:48 PM
Goofus's Avatar
Yes, it looks pretty nice for sure, think I lucked out. And the prior owner was not exactly an electrical genius, still sorting through the mis-connections which is a bit harder since he painted over EVERYTHING so the wiring colors are gone. May eventually give up and order a new harness, we'll see what the Spring brings!
I am Goof
Old 12-30-2020, 12:49 PM
Goofus's Avatar
It's a beast for sure, I was shocked at how well it handled 'too much' snow.
I am Goof
