Old 01-11-2021, 09:06 AM
ken6x6's Avatar
ken6x6 ken6x6 is offline
Finally got around to swapping the axle tubes out to the 30 mm shafts, got a set of braces from xtreme put on, which led to reworking a few mounting points on the kwik way supframe. It looks and feels extremely solid. And finally painted the subframe cub yellow. Looks much better now. Next ill be painting the loader cub yellow.
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 01-11-2021, 07:33 PM
Good move with the big axels, tubes and braces.
Old 01-11-2021, 10:38 PM
ken6x6's Avatar
Feels real solid now.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 01-15-2021, 02:59 PM
MSS7120's Avatar
MSS7120 MSS7120 is offline
Used my new to me 3165 to clear it's first significant snowfall. Got the front cab mounted light bar, beacon, and windshield wiper wired up with this nifty 6 circuit box. Need to get the rear lights wired. Then I will have 2 spare circuits.
Mark from Minnesota
3165 with CC Snow Blower, Front blade, Sims Cab
3185 with 3pt hitch, it runs now. But not well.
48in and 52in mower decks
2185 with mower from my dad when I have a project for it.
Massey Ferguson Model 70 corn planter.
CC yard cart
Old 01-25-2021, 09:03 PM
Since there is no snow on the ground, which is dandy in my opinion. As well
as in Georges if my memory serves me. I put the 125 to work doing a
little wood hauling. Tractor seemed happy for the job and owner always
loves hauling wood by mechanical means.
Old 02-02-2021, 04:52 PM
Nice pictures, I have been there a long time ago. Your wood must come from afar.
Up to 534 and counting...
Old 02-16-2021, 10:22 PM
farmall fred's Avatar
farmall fred farmall fred is offline
Default The 2382 snowblower tractor getting a workout
The 2382 is a repowered re badged 1872 with a 23 hp Command engine swap. It features a cab and a 451 blower. It is a snow eating beast. We had a major snowfall and wind so I had some good sized drifts to content with. This is the first time since I put the cab on the tractor that I really gave it a workout. I just need a way to get some engine heat in there to help keep the windshield clean. A couple of pictures of it in action.
Old 02-17-2021, 03:37 AM
Bryan S Bryan S is offline
Great pics, It looks like a Beast.
I've had my eyes out for a snow cab,
for my 2182 that's going to be my dedicated snow chucker.
I do have an idea for a defroster.
I wanted to do a initial test out tonight, after reading your post,
it jogged all the cobwebs upstairs...
but I can't seem to find my small cigar lighter
power inverter that I just had not so long ago.
Here's my idea. It involves a Presto Hot air popcorn popper
take the 3 small Phillips screws out of the base, and you have
an insane amount of hot forced air, in a small package.
Some dryer vent hose, as short as possible, a small power inverter,
a small battery, or use your tractors, 1/2 Size
Foil Deep Steam Table Pan, or full size one, and some hose clamps.
With the foil pan you would fold it long ways, to make a long,
very narrow channel, like what's used for a bare floor shop vac,
only narrower, to concentrate the hot air. Also cut the hole in the bottom part,
and prob pinch the center opening to help divert the air out to the ends,
(make a wider spray pattern so to speak) And last but surely not least,
your imagination. I'll take a pic of the hot air popper base,
and post it in the General Talk, for anybody who's curious. I think you might also be able too
use an old blow dryer, heat gun, etc?
Good luck with keeping that ice off the shield.
Maybe some Rain-X till you get it worked out.
Back in my snowmobile days we used to wax our shields to help
keep the snow and ice off, and from fogging up.
The Cub Pack. 70, 100 (creeper), 104, 122 (2), 1250, 1810, 1863, 2182, LTX 1050, SLTX 1050, SLT 1550, SLT 1554, Snow Chuckers 450, 451, 826T, 1030E, 2 plow blades. always looking for "just one more"
Old 02-17-2021, 10:52 AM
Goofus's Avatar
Goofus Goofus is offline
That's a lot of work for a bit of defrost. Check with your local Auto parts store as NAPA, Advanced Auto, and Autozone all carry a cigarette-lighter plug in heater that even comes with a mounting bracket. Likely among whatever auto stores are near you there's one collecting dust on a shelf waiting to serve you! Seems like that would be just what you need assuming your generator is in good condition. Used one in my '68 Plymouth Valiant for a couple winters until i could make time to replace the heater core .....
I am Goof
Old 02-17-2021, 10:55 AM
RLause's Avatar
RLause RLause is offline
Tom, that looks like a super setup. i got to use the 782 yesterday, some snow fall.
Richard
