Old 02-21-2021, 10:09 AM
Ambush Ambush is offline
You're probably right, never thought of that.
Old Cubs and Cub parts are about non existent in western Canada and about one per thousand square miles in my area and I have that one. But I'll be keeping my eyes open for a good cast iron pan. I do have a bunch of PTO and rear lift parts to trade.
Old 02-21-2021, 01:37 PM
ICOM 756 ICOM 756 is offline
theres a few in ny on fakebook that have tons of stuff.. i cannot say if they will send it that far.
also CT i think theres a guy that has tons of cub stuff..
i would replace. you know it will be in the back of your head all the time you riding it.
heres a few of them. no clue on how they are with shipping. i havent bought anything from them.. they r all fakebook. so i guess board doesnt allow them. but just use numbers off the end .
https://******************/marketpla...52507821672110
https://******************/marketpla...87118604839268
https://******************/marketpla...76454466024896
https://******************/marketpla...22175882453446
Old 02-21-2021, 10:37 PM
Thanks ICOM. Cast pans with the dipper extension seem rare.
Old 02-22-2021, 01:48 PM
no idea on how rare the deep dish pan is but here is another guy and he will ship.
i have 4 motors 10 to 14 and there all deep dish. so again no idea ..
something tells me this guy might have one
face book. com/marketplace/item/4033520333325402
Old 02-22-2021, 08:45 PM
WesternCannonball's Avatar
WesternCannonball WesternCannonball is offline
If you don't mind a road trip from BC to Yelm, WA, there's a guy down there who parts out the older cubs. I've done business with him many times. His name is Joel Cook, and he advertises on Craigslist all the time. Craigslist-Seattle-Farm and Garden-By Owner-Cub Cadet. If he ain't got it, it can't be found around here.
It all started with a little 122......
Old 02-22-2021, 10:40 PM
Thanks for the info Westerncannonball. I have friends that have Washington postal boxes.
I got everything run through the parts washer this morning and on closer inspection, I believe Darkminion had it right with the crank bearings. One is very raw! Good news is my old work place had two new old stock bearings for free.
I milled .008" off the head before it had nice crisp edges right to the combustion chamber, more than I thought it would need. I ground the valves and since they had been changed in recent history they cleaned up pretty quick. The black line, in the one pic, is the wear area after taking a couple thou off.
I also noticed that the top of the tappet adjustment was wore in from the end of valve stem. So I ground that ridge off too. That would give you a false feeler gauge reading when setting the valve clearance. Turned out to be about .003".
I dropped the block off and ordered a piston today.
Old 02-27-2021, 11:44 PM
Still waiting on a piston to arrive, but it's snowing now, so the sled dogs should get through a bit faster.
Until I can find a reasonably priced cast iron oil pan, I'm going to use this one. I cut studs from grade eight threaded rod. The threads in the pan are wallowed a bit in the top third, so I installed the studs with two part, metalized epoxy. The studs are threaded right to the bottom to ensure 100% thread use. The front stud length is fairly critical so they don't hit the axle in full articulation, but pretty easy to check without the motor attached to the pan.
Old 02-28-2021, 06:33 AM
ironman's Avatar
ironman ironman is offline
When re-installing, getting the motor and driveshaft aligned and coupled up usually requires a bit of sliding and maneuvering of the motor.
I hope the permanent studs do not complicate that for you.
Old 02-28-2021, 09:08 AM
^^^ Shouldn't be a problem? Same amount of wiggle room as with bolts.
Do you normally loosen the pan bolts whenever removing and reinstalling the driveline?
Old 02-28-2021, 09:38 AM
Yes you do, but you can always install the driveshaft from the rear.
You can strip out a nut easier than a bolt that is why they use bolts in the pan, hopefully you can find a pan...
Up to 534 and counting...
