Old 03-15-2021, 03:40 PM
thadscub's Avatar
thadscub thadscub is offline
Default Broken frame at left front engine mount
Okay guys, I have had a major fail the frame on the left side where the front bolt is broke out. Can that be welder back? If so, how thick is the frame or do I need to replace frame?
Thanks,
Thad
Old 03-15-2021, 04:05 PM
It would be most helpful to us if we knew what tractor model you are working on !!
Old 03-15-2021, 06:22 PM
green407's Avatar
green407 green407 is offline
This, and pictures would also be helpful.
128 X 2, 129, 149, 1250, 1450 x 2
Old 03-15-2021, 08:48 PM
thadscub's Avatar
122 Cub Cadet.
Old 03-15-2021, 08:49 PM
thadscub's Avatar
Broke right where the front axle mounts to the frame
Old 03-15-2021, 09:08 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
This is a common crack for a tractor that is 50+ years old and has worked hard. I found this crack among many on this 102. It is an easy weld repair. It was also at the left front engine mount.
Queen Of The Quietlines!
Old 03-16-2021, 08:59 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Very common and something a spot of weld can fix.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 03-16-2021, 09:40 AM
thadscub's Avatar
its not just a crack broke out but i see it is weldable i will get it welded as i am not a great welder
