Okay guys, I have had a major fail the frame on the left side where the front bolt is broke out. Can that be welder back? If so, how thick is the frame or do I need to replace frame?
Thanks, Thad |
It would be most helpful to us if we knew what tractor model you are working on !!
This, and pictures would also be helpful.
128 X 2, 129, 149, 1250, 1450 x 2 |
122 Cub Cadet.
Broke right where the front axle mounts to the frame
This is a common crack for a tractor that is 50+ years old and has worked hard. I found this crack among many on this 102. It is an easy weld repair. It was also at the left front engine mount.
Queen Of The Quietlines!
Very common and something a spot of weld can fix.
61 and 63 Originals 123 (2) 782D 106, 147, 122 102 parts It's only original ONCE!
its not just a crack broke out but i see it is weldable i will get it welded as i am not a great welder
