Old 04-17-2021, 09:54 AM
thadscub's Avatar
thadscub thadscub is offline
Default Shed ramp
hi
I just got a new shed for my Cub Cadet 122, but I need to make a ramp. It has a about a 16 inch difference from the ground to the floor. What size ramp would I need?
Thad
Old 04-17-2021, 10:38 AM
ironman's Avatar
ironman ironman is offline
Prolly one that goes up 16 inches.
Old 04-17-2021, 10:52 AM
thadscub's Avatar
i mean length as i don't know the rise a 122 with a tiller or more deck would go up without scraping
Old 04-17-2021, 02:07 PM
Billy-O's Avatar
Billy-O Billy-O is offline
I would hazard a guess an say maybe the run be 3-4 times the height! 48 to 64 inches long!
Plow blade
#2 Cart
QA36 snowthower
Old 04-17-2021, 02:26 PM
Garyoh5a Garyoh5a is offline
ADA ramps are 1” elevated in 12” of run. Nice rise, however you’d need 16’ of ramp. 6-7’ of ramp might do the job
Old 04-17-2021, 05:45 PM
mortten mortten is offline
Mine rises 12 inches. It’s 5 feet long.
File Type: jpg 537FF0B1-49B6-48C3-B38E-08514DC2BE5C.jpg (27.9 KB, 99 views)
Doug
QA-36A
42" blade
Old 04-17-2021, 07:18 PM
Goofus's Avatar
Goofus Goofus is offline
Your profile shows you in Colorado. If you want to get it out and back in during winter you'll want a minimum of 8 feet but 12 is probably a better number, my 8 feet for a 12 inch rise causes minor problems with traction after an ice storm.
If that's not an issue I'd suggest you mock one up to try with your implements, every mount and every tractor is slightly different as wear, adjustment, condition, tires, etc all can make your set-up clearance different from the next guy.
I am Goof
Old 04-17-2021, 10:44 PM
TheSaturnV's Avatar
Get some scrap OSB and 2 x 4's off a jobsite and run some trials.
Old 04-18-2021, 10:10 AM
That or just make one out of gravel.
Old 04-18-2021, 09:45 PM
Getter-Done's Avatar
Getter-Done Getter-Done is offline
A 8 foot ramp (from level ground) would be 9.59 degrees.
You could build a two stage ramp.
This would make the second level of the ramp
an easier transition.
Example Picture
